AHS
I've got 2 TR3A transmissions I'm cleaning and checking over. On the first transmission, the clutch fork shaft slid out easily and the steel dome over the base of the shifter came off with some minor persuasion. On the second transmission, neither one wants to cooperate.
The square headed bolt is out of the clutch fork and the shaft now freely rotates about 30 degrees in the fork and slides back and forth 1/8" or so, but the fork won't slide off the shaft. The shaft retention bolts have been removed and the shaft will slide as far as the fork hitting the inside of the bell. I've both tapped on the shaft and put moderate torque on the clutch release lever. I'm suspecting a large burr, but I don't want to force it.
Both the long and short bolts have been removed from the shifter dome, but it still won't budge. I've also sprayed a lot of penetrating oil in there. I've already broken a large strap wrench trying to get the dome to move. There is enough of a gap underneath the dome to get a pry bar in, but I've only put a little force there so as not to damage the aluminum shift extension casting. It didn't want to move that way either.
Any suggestions would be greatly appreciated.
Thanks,
Andy
Thanks,
Andy
