TR2/3/3A TR3 tranny, dipstick and fill
tomgt6
I am working on someones TR3A and the tranny has a dip stick how do I get it out. I can spin it but can't seem to pull it out.
Also I need to change the fluid. Drain is easy but do I need to take the tunnel off to refill it if not on what side is the fill plug and how do you guys get it filled with what gizmos. Or if I can get the dip stick out can I fill from there?
Thanks
ISTR that the dip stick has a cork or rubber stopper that seals it to the tranny. You will have to pry or pull it straight out. Refill is through the dip stick hole using a funnel.
thanks.
The tunnel carpet unsnaps and comes out. You will find a rubber plug to access the dipstick on the tunnel.
John
White79MGB TR2/3/3A Access to TR3 tranny dipstick? Triumph 3
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
Got_All_4 TR2/3/3A J type on a TR3 tranny Triumph 3
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
Lukens TR2/3/3A TR3 A tranny questions. Triumph 8
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
R TR2/3/3A Will this Tranny fit my TR3 ?? Triumph 9
G TR2/3/3A TR3 Tranny Triumph 7
newmexTR3 TR2/3/3A TR3 tranny fluid change Triumph 15
Tinkerman TR2/3/3A TR3 Tranny, Starting on it! Triumph 6
Moseso TR2/3/3A TR3 Starter/flywheel/tranny case Triumph 5
prb51 TR2/3/3A TR3 tranny seals Triumph 3
G TR2/3/3A Quick Help - taking the cover off a TR3 tranny Triumph 3
G TR2/3/3A Tearing Down my Free TR3 Engine/Tranny Triumph 13
PeterK TR2/3/3A Which TR3 tranny is this? Triumph 4
A TR2/3/3A TR3 tranny question Triumph 12
RichB4493 Wanted TR3 Hardtop mounting pieces Triumph Classifieds 1
vpanza For Sale Triumph TR3 - TR2 Parts Windshield, Head, Steering column, Transmission, etc Triumph Classifieds 8
mctriumph SOLD!! TR3/4 converted fan Triumph Classifieds 6
K TR2/3/3A Need a link to TR3's racing back in the day........ Triumph 3
R TR2/3/3A TR3 Heater Fan Triumph 8
W TR2/3/3A TR3 dead cylinder ? Triumph 58
G No directional signals or brake lights on 60 Tr3. Triumph 2
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 11
RichB4493 TR2/3/3A Rare “TR3” spotted on safari Triumph 3
71TR6 For Sale TR3 Radiator with crank hole- refurbished Triumph Classifieds 3
jfarris For Sale Original Style TR3 Luggage Rack Triumph Classifieds 0
jfarris For Sale TR3 early used fan $25 + shipping Triumph Classifieds 1
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
IdahoNuke For Sale Free TR3 Seats Triumph Classifieds 3
T Wanted Wanted TR3 rust free nut & bolt restoration Triumph Classifieds 13
R TR2/3/3A 1956 tr3 value? Triumph 7
cguild TR2/3/3A TR3 1991cc engine emits black soot from exhaust Triumph 13
D TR2/3/3A Black TR3 Triumph 20
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A The TR3 is up and running again.... Triumph 7
S TR2/3/3A Battery box for a triumph tr3 Triumph 5
J TR2/3/3A TR3 age Triumph 4
G For Sale TR3 original metal air filters Triumph Classifieds 0
G For Sale 1960 TR3 fitted black cover. Triumph Classifieds 0
S TR2/3/3A tr3 sat all winter Triumph 15
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 5
W TR2/3/3A TR3 Seat Belts Triumph 10
R TR2/3/3A TR3 Timminge Triumph 11
J SOLD!! Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J SOLD!! TR2 TR3 Tie Member Triumph Classifieds 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
