TR3 Oil Temperature readings
karls59tr
Anyone happen to know what would be considered a "normal" oil temperature reading for a basically stock TR3 ie. mild street cam and header.
aeronca65t
A "good" temp range would be 200 to 225F.
Your oil should not go above about 260F for very long. Getting the oil to 300F (even for a short time) would probably be real bad.
You want the oil to go above 212F (at sea-level) so that you boil out any of the water that condenses in the oil as the engine cools down after running.
This is sort of a problem with some of our cars, because they may just be "lightly used" and driven rarely. In some cars the oil rarely goes over 150F. The only solution is to change the oil more frequently (and try to give the car a "good run" more often).
My Spridget (with the 1500 Spitfire-based engine) rarely got above 215F and it was only used for racing. The regular water cooling system kept the engine (and oil) pretty cool. This is why I never bothered with an oil cooler. I am changing over to a "new" (1275) engine and I'll be monitoring the oil temps. If they're under 220F, I'll won't add an oil cooler.
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
B TR2/3/3A normal oil pressure in TR3 Triumph 6
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
G TR2/3/3A TR3 Oil Strainer Repair Triumph 6
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
P TR2/3/3A TR3 Transmission oil Triumph 13
M TR2/3/3A TR3 oil filter cap needed Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
J TR2/3/3A TR3 oil pressure hose question Triumph 1
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
RedTR3 TR2/3/3A TR3 Oil Breather Mounting Triumph 6
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
M TR2/3/3A TR3 aluminum oil pan Triumph 9
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
TomMull TR2/3/3A TR3 oil gallery plugs Triumph 2
PatGalvin TR2/3/3A Target Oil Pressure for new TR3 Rebuild? Triumph 4
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
S TR2/3/3A tr3 tranys oil Triumph 10
mountainman TR2/3/3A TR3 Leaking oil pan Triumph 17
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
S TR2/3/3A tr3 Shock oil leaking Triumph 2
J TR2/3/3A TR3 Oil Galley Plug, HELP!! Triumph 4
toysrrus TR2/3/3A Re: TR3 "Front" Main Oil Seal: Triumph 3
S TR2/3/3A little brackets for oil line tr3 Triumph 3
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
newmexTR3 TR2/3/3A Oil pressure running high - TR3 Triumph 6
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
newmexTR3 TR2/3/3A TR3 Oil Pan thread repair Triumph 6
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
