TR2/3/3A tr3 Lucas coil
sp53
On an old style tr3 Lucas coil there is a screw in the center. Can this screw be removed? What I did was to attempt to remove the screw and some oil came out. Does anyone know if I damaged the coil or not.
Sp53
Deleted member 3577
Oil lubricates the smoke so it doesn't get stuck in the wires.
If you want another coil like the one you have.....
PM me w/ your address and I'll send you an almost new one, free.
(Plenty of smoke lube still inside)
S
sp53
Hi WTN I really appreciate the offer and I want the coil, but I do not have your number. If you can post it or give me your email, I will get in touch.
Thank you
Sp53
jsneddon
PM means private message if you missed that part - just click on WTN's name next to his post and then click on send a Private Message. Also look for messages to you by looking for a little flashing envelope on the upper left part of the screen where it says "Selcome sp53" - click on the envelope to read your private forum emails.
dklawson
WTN, I thought about you a lot this past weekend. I was up at VIR for the Gold Cup races and saw several Elvas... none as nice as the one in your avatar of course!
jayhawk
[ QUOTE ]
On an old style tr3 Lucas coil there is a screw in the center. Can this screw be removed? What I did was to attempt to remove the screw and some oil came out. Does anyone know if I damaged the coil or not. Sp53
[/ QUOTE ]
If you have the same old coil I had, it has a threaded tower on top that fastens to a hollow "nut" through which the wire to the distributor goes. The coil end of the wire should have about 1/2 inch of bare wire that goes through a washer and then is splayed out to contact the bottom of the socket of the coil. The "nut" is removable but to my knowledge, not the threaded portion of the coil. My coil was fried at the bottom of that hole and would no longer make good contact so I replaced the coil with the "sport" lucas coil.
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
tinman58 TR2/3/3A TR3 lights Lucas gremlin Triumph 2
M TR2/3/3A What is the Lucas part # for a TR3 control box Triumph 2
T TR2/3/3A Lucas/Peter Pan part two. [TR3 wiper] Thanks Triumph 3
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
R TR2/3/3A TR3 Wiper motor Triumph 10
