TR2/3/3A TR3 Heater Core PSI
Mkutz
I'm taking my TR3 heater core to a radiator shop to get boiled out and to check for leaks, and recall seeing a post about the fragilty of this part...What is the max amount of PSI I should tell the radiator shop to take it to on the pressure test? 4-5 PSI? At $500 for new, I'd hate to see this get blown apart.
TR3driver
Great Pumpkin - R.I.P
Just tell them it's from a car with a 4 psi system. They will test higher than that, to give you a bit of safety margin (you've never lived until that core blows apart and sprays your lap with hot antifreeze), but I believe not as high as usual.
BTW, the pressure is not constant throughout the cooling system when the engine is running. If it was, the water wouldn't move /bcforum/images/%%GRAEMLIN_URL%%/smile.gif Which is another reason to test higher than 4 psi.
sp53
Yes that type of design will open up like an accordion under too much pressure if it is not contained. One way to contain the core is to have an old top and bottom with the motor removed and just put the clips back on. I guess you could clamp it somehow with a couple of C clamps. The first time I took one to a radiator shop, the guy gave the core to the village idiot to do the testing and cleaning. When I got it back, it was about an inch bigger. I was able to put the core in a vise and smash it back down, so I could get it into the container. But, I do not think I ever used it again. I clean them out at home now by shaking them up side down over a sink, using soap and water and perhaps heat them in kinda boiling water on the stove. The old ones are fragile and the new ones are generic (you have to modify) or as Moss puts it, a Matrix, and they are expensive.
Sp53
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
parkerg1 TR2/3/3A TR3 Heater Triumph 10
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
M TR2/3/3A TR3 Heater Triumph 34
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
M TR2/3/3A TR3 heater install picture needed Triumph 33
Lukens TR2/3/3A Would you sell your TR3 heater? Triumph 18
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
Russ Austin TR2/3/3A Attempting to install a heater in my TR3 Triumph 39
M TR2/3/3A Heater removal in TR3 Triumph 13
H TR2/3/3A TR3 heater options Triumph 9
ekamm TR2/3/3A Tr3 heater valve Triumph 12
T TR2/3/3A TR3 heater pipe bracket Triumph 6
S TR2/3/3A Repairing a tr3 heater? Triumph 14
S TR2/3/3A tr3 heater Triumph 7
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
RedTR3 TR2/3/3A TR3 Heater Coolant Flow Direction Triumph 3
D TR2/3/3A TR3 heater reinstall problems Triumph 4
RedTR3 TR2/3/3A TR3 Heater Question Triumph 8
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
S TR2/3/3A Tr3 heater wirer Triumph 8
M_Pied_Lourd TR2/3/3A TR3 Heater Finish Triumph 8
S TR2/3/3A heater attaching piece tr3 Triumph 4
newmexTR3 TR2/3/3A TR3 heater hose install Triumph 4
Tinkerman TR2/3/3A Unknown Part TR3? Heater Bracket? Triumph 5
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
newmexTR3 TR2/3/3A tr3 heater vacuum lock? Triumph 2
S TR2/3/3A TR3 pipe leaking [housing to heater] Triumph 3
Got_All_4 TR2/3/3A My TR3 heater fan switch is broken Triumph 8
T TR4/4A TR3 / TR4 heater question Triumph 2
Geo Hahn TR2/3/3A TR3 Heater Alternatives Triumph 11
J Spitfire Spitfire heater upgrade to TR3? Triumph 7
PeterK TR2/3/3A TR3 heater part Triumph 0
