    Do you enjoy BCF? Is our forum a useful resource? Do you want to ensure we can stay online?
    Please consider supporting us by **Upgrading**
    [Silver & above members qualify for a BCF email address... Click for Details
TR2/3/3A Tr3 Gas pedal height from floor
sp53
Hi all, we had a nice day in the Seattle area today, so I dug out my 58 tr3 and took it for a drive. It had not been driven for some time. Anyway the 58 seems a lot different than the 61. I have only driven the 61 about 25 miles, but they seem so different. For example, the gas pedal is an inch and a half high up in the 58. If I take a straight edge across the brake and clutch pedal and measure down to the gas on the 58 it is 2 3/4 and 4 inches down on the 61. What I want to do is bend the pedal up on the 61 an inch or so, but I want to leave it in the car when I do it. Does anybody have any suggestions on how to hold the pedal and bend it up cold, better yet has anyone bent the pedal when it is in the car? This one of those things where experience is nice.
Steve
Darrell_Walker
Don't you have any adjustment in the linkage that you could change, instead of bending the pedal?
angelfj1
Steve
The rod to which the pedal is welded is not adjustable since it is pinned to the end of the cross shaft. Same thing with the lever which is pinned to the other end of the cross shaft. If these pins fell out at some time in the past the PO may have reattached them using another means such as drilling another hole or using a set screw. (I have seen both methods employed). This would have changed the intended alignment Another possibility is that the carb linkage rods have been mis-adjusted and need to be returned to their correct position. See diagram below.
S
sp53
Hi hear you Frank I had the shaft out when I sandblasted the tub and put new pins in the shaft. It looks like the pedal is just different/bent. I did purchase the vehicle in pieces with the engine out and whether the PO bent it I do not know. I looked at another shaft I have and it is difficult to compare with the others. Once the engine is in I find those shafts a hassle to take out because of all the bends. The reason I posted the problem was that I was hoping the problem was common, but? The linkage seems to work fine my fear is that when I get the carpet in the pedal will be a problem.
TR3driver
Great Pumpkin - R.I.P
I agree, not a good thing to try to bend in the car. If you twist off one of those pins, you will not be happy!
First make sure that lever 47 is clamped to the throttle shaft 37 so that with the throttle closed it makes about a 45 degree angle to horizontal. Then set the short link 77, so the bellcrank 79 does the same. Then you can adjust pedal position (if still necessary) using the long link 78.
You might also want to examine the joint between 79 & 80 for wear. Mine was so badly worn that not only was it losing a lot of motion, but the bellcrank was dragging against the bolt head and causing the linkage to bind.
BTW, Frank's diagram shows TR2 carbs. But the linkage should be the same on your TR3.
mallard
Steve I can take some pictures of my pedal assembly on Sunday if you would like. You maybe able to see if they are bent the same, let me know. They are not in the car, they are hanging on the wall.
vivdownunder
This is how I recall slightly adjusting the accel pedal for heal and toe driving back in the comp days.
A suitable width wedge of timber was inserted between the accel cross rod and the underside of the clutch/brake pedal pivot cover. This chocked the cross rod to take any pressure off the carby linkages.
Then we grabbed the top part of the accel pedal where the rod is welded on and pulled it gently forward.
Viv.
S
sp53
I like it Viv it appeals to the carpenter in me. I am going to check some of the angles that Randall talked about to see if it can be adjusted. The leakage I used was stuff I collected over the years and perhaps the long rod is too long or short or something, but I do not know if there would that much adjustment. Keith I was trying to find a way of establishing a method to see the bends, but there are just too many bends to correlate to establish what is bent and what is not.
Steve
TR3driver
Here's a shot of the linkage from TS39781LO. The bends above the pedal are no doubt from over-enthusiastic operation, but it was working fine before the car got wrecked. BTW, the pedal stop should stick through the carpet.
Twosheds
The accelerator pedal in the TR3 racecar was too low for me to heel-and-toe when I bought the car. The arm was bent over the stop.
I can only imagine that the PO tried to go faster by pushing harder and harder on the pedal, bending it!
I took the whole assembly out and straightened it with a BFH so I could heel-and-toe.
S
sp53
Thanks Randall for the pic. The area between the pedal and the 90 that returns through the firewall is where I think there might be a problem with mine. Some place in there is where I might try a bend if I cannot adjust it out. There could have been some over enthusiastic driving there also. I check my linkage and the long rod is 14 and the short is 3 ½ and the clamp 47 is less than 45, but I think that would give it more pedal in the cab. I did notice that the bell crank could go in two ways, but I do not think it would make a difference.
steve
M
Member 10617
Speaking of gas pedals, the gas pedal in my 58TR3 is very, very stiff. I've gotten used to it, but anyone else who drives it comments on how clunky it feels.
Someone said it may be the return spring.
I think something needs to be lubricated. But I read somewhere there are some spots on the accelerator linkage that should not be lubricated.
Any guidance will be appreciated.
vivdownunder
Ed, firstly check in the footwell that something like carpet isn't chafing the accel pedal rod. Check that nothing is binding on the accel rod where it crosses behind the engine.
Then try disconnecting the carby linkages from the accel pedal to locate which end of the gubbins has the problem.
A convenient place to do this is behind the rear carby. Unbolt the throttle rod linkage pin from its thread in the accel lever. I think it takes about a 3/8" AF spanner.
The long and short throttle rod swivel unions have to be free and lubed, as does the bell crank axle under the front carby.
The carby spindles have to rotate and return to their stops freely.
The accel pedal rod rotates via a nylon bush at each end, clamped between the mount brackets.
Regards,
Viv.
TR3driver
Some other problems I've had over the years:
1) The balls in the joints tend to wear oblong. If someone has tried to snug them up with the adjustments, they can bind at the limit of rotation. In my case, they were actually holding the throttles open slightly, making it impossible to get a consistent idle rpm. Replacement is the only reasonable solution (although there may be cheaper sources than the usual LBC suppliers).
2) If the RH motor mount is signficantly sagged, the long link can drag on the underside of the intake manifold. Took me a long time to find that one!
3) PO had replaced the mills pins with bolts, which had worn the holes and produced large amounts of play.
The nylon bushes should not need to be lubricated, but IMO it won't hurt, and a very small amount might help. All of the other joints do need to be lubed, and preferably disassembled and cleaned every decade or two IMO. Don't forget an occasional drop of oil on the throttle spindles themselves. For the front side, I just put a drop on top of the return spring, and rely on vacuum leakage to eventually pull it into the shaft/body joint.
M
Member 10617
All good advice and guidance. I will give all this a try and see if I can make the pedal operate smoothly. Many thanks, as usual,
S TR2/3/3A Tr3 gas pedal Triumph 3
S TR2/3/3A Tr3 gas pedal shaft socket Triumph 7
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
J TR2/3/3A TR3 gas tank mystery Triumph 5
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
S TR2/3/3A TR3 gas filler cap Triumph 1
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
tinman58 TR2/3/3A TR3 gas tank? Triumph 2
T TR2/3/3A TR3 aluminum gas tank on eBay Triumph 4
T TR2/3/3A remove a tr3 gas tank Triumph 7
K TR2/3/3A TR3 gas tank inlet size? Triumph 2
M TR2/3/3A TR3 gas cap question Triumph 4
R TR2/3/3A TR3 gas tank Triumph 13
J TR2/3/3A Help!! Gas smell from Tr3! Triumph 21
T TR2/3/3A TR3 gas tank vent Triumph 12
S TR2/3/3A tr3 gas gauge calibration resisters Triumph 12
af3683 TR2/3/3A TR3 Trunk Plugs Near Gas Tank Triumph 3
af3683 TR2/3/3A Installing TR3 Millboard Gas Tank Cover Panel Triumph 5
S TR2/3/3A tr3 gas gauge Triumph 5
T TR2/3/3A TR3 gas tanks Triumph 9
mountainman TR2/3/3A Tr3 Gas Additives Triumph 23
K TR2/3/3A 57 TR3 gas tank hold down strap mistery? Triumph 5
S TR2/3/3A One more tr3 gas tank? Triumph 1
S TR2/3/3A late tr3 gas cap? Triumph 5
S TR4/4A late tr3 and tr4 gas caps Triumph 4
S TR2/3/3A Tr3 gas cap vent Triumph 0
S TR2/3/3A tr3 gas tank vent Triumph 3
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
S TR2/3/3A gas tank in a 1961 tr3 Triumph 12
S TR2/3/3A Tr3 gas tank again Triumph 3
S TR2/3/3A Tr3 gas tanks Triumph 7
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
tinman58 TR2/3/3A Another TR3 gas tank ? Triumph 3
mountainman TR2/3/3A TR3 Gas Tank Question Triumph 7
H TR2/3/3A TR3- installing gas tank = nightmare Triumph 18
S TR2/3/3A gas gauge TR3 Triumph 7
J TR2/3/3A gas leak on a TR3 Triumph 4
martx-5 TR2/3/3A TR3 Gas Tank Installation Triumph 5
RedTR3 TR2/3/3A TR3 - Gas odor and poor mileage Triumph 5
S TR2/3/3A Tr3 gas tank repair Triumph 9
J TR2/3/3A tr3 and unleaded gas Triumph 9
martx-5 TR2/3/3A TR3 Gas Tank Triumph 3
S TR2/3/3A TR3 Gas Mileage Triumph 9
D TR2/3/3A TR3 gas gage Triumph 2
S TR2/3/3A TR3 Hard Starting Triumph 4
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
H For Sale 1956 Small Mouth TR3 Kit Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
