TR2/3/3A Tr3 brake calipers
TFR
Will Tr6 calipers mount on a TR3 brake mount? Need a new right caliper and can't find a decent replacement.
martx-5
The short answer is NO. The mounting bracket for the TR6 calipers is different then the TR3 mounting bracket. The TR6 bracket has it's caliper mounting holes spaced farther out then the TR3's. Also, which calipers do you have on your TR3?? The earlier calipers are a single casting with the bridge pipe and uses an 11" rotor. The later ones use a 10 3/4" rotor. If you have the smaller rotors, you could theoretically use the TR6 bracket with a TR6 caliper, but then it would probably be best to do that to both sides.
TR3driver
Great Pumpkin - R.I.P
I agree that TR6 calipers will not interchange unless you also change the mounting bracket and rotors. But the later TR3A calipers will interchange with the earlier TR3/A calipers (the ones with the crossover pipe). Even very early TR4 still had 11" rotors (but there were supposedly some TR3Bs with the smaller rotors).
Larry, there are currently two pairs of later TR3A/early TR4 calipers on eBay. The change point was slightly before TS60000, so these should be the proper calipers for your car.
trfourtune
I have a pair of the early calipers on my 61 tr4 parts car. they were rebuilt before it was parked for a long time. I'm not sure if the pistons are free any more but i could look into it if you are interested. $40 (canadian) plus shipping for the pair.
Rob
PS-these are the same as the tr3 calipers.
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
H TR2/3/3A Cleaning TR3 Brake Calipers Triumph 6
Tinkerman TR2/3/3A Front Brake Calipers TR3 Late Triumph 6
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
K TR2/3/3A TR3 Brake MC pushrod? Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
S TR2/3/3A brake reservoir on a tr3 Triumph 8
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
K TR2/3/3A TR3 Brake drums on a 1956? Triumph 5
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
mgedit TR2/3/3A Source for Brake Pipe 56 TR3 Triumph 9
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
D TR2/3/3A TR3 brake rotor question Triumph 4
J TR2/3/3A Brake line advice for my TR3 Triumph 5
L TR2/3/3A TR3 Brake Rotor Thickness Triumph 18
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
K TR2/3/3A TR3 10" Brake Drums? Triumph 10
af3683 TR2/3/3A Original Paint on TR3 Brake Drums Triumph 1
K TR2/3/3A TR3 Brake Proportioning Valve? Triumph 2
S TR2/3/3A rear brake lines tr3 Triumph 3
C TR2/3/3A TR3 Brake pads interchangeable? Triumph 1
mgedit TR2/3/3A 56 TR3 Clutch/Brake Pedals Triumph 4
Got_All_4 TR2/3/3A TR3 E brake problems Triumph 19
Got_All_4 TR2/3/3A What's wrong with this brake fluid? TR3 Triumph 19
S TR2/3/3A Should TR3 rear brake slave cylinders move? Triumph 4
K TR2/3/3A Installing Brake Switch TR3? Triumph 6
B TR2/3/3A TR3 brake restrictor valve Triumph 6
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
K TR2/3/3A TR3 Rear Brake back plate... Triumph 2
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
K TR2/3/3A TR3 rear brake adjuster seized? Triumph 10
T TR2/3/3A tr3 rear brake band installation question Triumph 7
S TR2/3/3A tr3 e-brake handle Triumph 4
T TR2/3/3A TR3 front brake line routing Triumph 3
S TR2/3/3A tr3 brake restrictor Triumph 14
NutmegCT TR2/3/3A TR3 brake [?] squeak Triumph 14
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
S TR2/3/3A brake lines and rubber bumpers tr3 Triumph 12
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
