    If you enjoy BCF and find our forum a useful resource and want to ensure we can stay online...
    Please consider supporting us by **Upgrading**
TR2/3/3A tr3 and unleaded gas
jsp17268
I have got a tr3a and i was wondering what the thought was on running unleaded gas without the new valve guides and valve seats? or if anything else needs to be done to run unleaded gas
thnaks
mrv8q
FWIW, I run my '59, w/ 64k miles, and use unleaded premium, 91 Octane here in L.A. The car is completely original, I don't think the engine's ever been apart. No knocks, seems to run fine, and I've had her at 90mph for short bursts here and there. Every now and again, I'll put in a little lead additive... I might use more if I ran it for extended runs, but I rarely put on over 100 miles at any one time. If I ever do the head, I 'd probably have the upgraded valves put in then. Of course, YMMV!
Don Elliott
I drove my TR3A 43,000 miles on unleaded gas with the original head in good condition without the steel inserts for the exhaust valves before I had to have them added. Toward the end of that 43,000 muiles the cast iron was receding so the valve gap was closing down from 0.012" to 0.002" every 1000 miles. This is what tells you that you need to do the conversion. I had an engine re-build shop do the job. I supplied him with 8 new valves for unleaded, 8 new valve guides for unleaded and he put in the inserts he was familiar with and he had them in stock. He preferred this because he has his own tooling for his machine and he knows that when he presses them into the head, the interference fit will guarantee that they will stay in place. I have heard of several TR3A owners where an insert for one of the exhaust valves has become loose and fallen down to ruin the valve and seat area, usually with a lot of noise. You don't want this to happen while on a long trip from home. I did this in 2000, just before I drove Montreal to Portland Oregon for VTR. That trip was 7250 miles. There were no problems. Since 2000, I have driven another 51,000 miles and never had to re-set the valve clearances - but I still check them every 5,000 miles or so.
Andrew Mace
So far I've put 25,000 miles on my Herald (with an untouched, original engine) using Premium Unleaded, and with no ill effects. And a Herald engine is far more stressed than any TR3 engine.
Do any "conversion" WHEN you need it. Until then, enjoy the car!
NutmegCT
Dumb question: does it hurt anything to go ahead and add some "lead substitute" to a TR3A? as a kind of preventive measure?
Tom
Tomster
"Most" lead substitutes or additive contain no lead.
I did a wack of snoopin on this for the last two driving seasons. Don't worry about it, see Andrew and Don's responses above
Don Elliott
I never believed in "snake oil". So I never used any additives for unleaded gas. The TR Register in England did an extensive study of many products and came to the result that there were 6 that helped. These products are available in UK.
Will it hurt ? Probably not. Will it help ? Who knows ? Will it cost you ? Yes.
You'll have to bite the bullet some day and do the exhaust valve seat inserts. If that's 3 years down the road or 4 years, it'll be more expensive to do it later than now. It depends how hard you like to drive and how many miles you plan to do over the next year or years. Don't leave it too late.
trfourtune
stupid question,
is there a reason to put in inserts on the intake side other than if you have an aluminum head?
Rob
Geo Hahn
I drove 25 years on unleaded and noticed no significant recession... finally did the hardened exhaust seats when I had the head off for other work.
I would think just doing the exhaust makes sense. I think if you do both the seats would overlap so they would have to do the intake seat first, then the cut for the exhaust seat taking some material out of the intake seat.
Don Elliott
The intake valves do not suffer from the problem of valve seat recession. The cool air/fuel mixture coming into the combustion chamber prevents the cast iron head from wearing away at the cast iron intake valve seats. It's the exhaust valves that need the inserts. When I had mine done after 43,000 miles on unleaded gas, I took the valves out and the exhaust valves were razor sharp on the edges. Once it was off, I changed all 8 valves. Some of those I took out at 123,000 miles from new were still the original valves.
Don Elliott, Original Owner, 1958 TR3A
https://www.triumphest2006.com/images/clubcars/30donelliott'str3.jpg
D TR2/3/3A TR3 repair in Cincinnati Triumph 0
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 6
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
K TR2/3/3A TR3 Brake MC pushrod? Triumph 0
K TR2/3/3A I saw a 59 TR3 today with an aluminium windscreen! Triumph 5
T TR2/3/3A tr3 head gasket Triumph 38
T TR2/3/3A TR3 Fuse Question Triumph 14
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 4
B TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 1
S TR2/3/3A new to me tr3 Triumph 11
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
Donald1107 TR2/3/3A TR3 Odometer Triumph 12
Sarastro Another SoCal TR3 Spotted 1
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
R TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
C For Sale 1959 TR3 - Unrestored survivor car Triumph Classifieds 2
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
D TR2/3/3A tr3 branchement demarreur Triumph 2
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
D TR2/3/3A electricité tr3 a Triumph 2
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
G TR2/3/3A Finding a long lost TR3 Triumph 4
1 TR3 Fender spats sold on EBay. Triumph 5
J TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Pool Dad 1960 TR3 engine serial number Triumph 14
T TR2/3/3A TR3 coolant hoses Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
J TR2/3/3A "TR3" painted on the engine block Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
J TR2/3/3A TR3 gas tank mystery Triumph 5
