TR2/3/3A TR3 aluminum gas tank on eBay
TR4nut
A friend of mine bought one from that ebay vendor a few months ago. It was good quality and an easy bolt in replacement. Only minor issue I think he had was the tank had a little dust in it and he wound up clogging a filter initially. But that problem was quickly resolved.
luke44
I bought one. The way I figured it, the chance of internal rusting with a steel tank given the car is not driven all year, and given todays gas, it was well worth it.
It was <span style="font-style: italic">so</span> pretty I just couldn't bring myself to paint it, so I clear coated it. Easy install too -- fit perfectly. I'm very happy with it.
Another picture from the front....
PatGalvin
darn that's pretty. Luke, you have one shiny TR3! Could eat off the floor pans or the shop floor. That's impressive. Some are scared just to walk through my garage!!
Pat
hondo402000
unless you have holes in your tank I think you can get a POR gas tank sealer for around 50 buck that will seal any rust in that tank
I did mine on my TR6, I also sand blasted the interior by sticking the sand blasting hose in the taknk and just moving it around for about 15 minutes, plus the sand stays in the tank, you can vacuum it out and reuse the sand, when done vacuum the sand out and pour the sealer in, swirl around and you are done, been 3 years and no issues I think it will seal small pin holes too
Hondo
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 7
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
M TR2/3/3A TR3 Aluminum Radiator [Wizard] Triumph 18
M TR2/3/3A TR3 aluminum oil pan Triumph 9
S TR2/3/3A aluminum side curtains tr3 Triumph 3
K TR2/3/3A Aluminum TR3 Triumph 1
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
newmexTR3 TR2/3/3A TR3 aluminum replacement radiators Triumph 9
mcguijo TR2/3/3A Cast Aluminum Valve Cover TR3 Triumph 5
J TR4/4A Aluminum Sump made for TR3-TR4? Triumph 15
1 TR3 Fender spats sold on EBay. Triumph 0
J TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 0
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Pool Dad 1960 TR3 engine serial number Triumph 14
T TR2/3/3A TR3 coolant hoses Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
J TR2/3/3A "TR3" painted on the engine block Triumph 13
J TR2/3/3A TR3 Rear seat Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
J TR2/3/3A TR3 gas tank mystery Triumph 5
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
T TR2/3/3A tr3 front carpet replacement Triumph 5
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 5
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR2/3/3A TR3 Hard Top Triumph 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 13
M TR2/3/3A Defective master cylinders Tr3 Triumph 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
M master cylinder brake/clutch Tr3 Triumph Classifieds 6
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Tr3aguy TR2/3/3A Started a Car revival channel for the TR3 Triumph 12
J TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
D 1957 Triumph Tr3 Triumph Classifieds 2
P TR2/3/3A tr3 side curtains Triumph 4
banjojambo Triumph tr3 vertical link wobble Triumph 2
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
C TR2/3/3A TR3 close by Triumph 2
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
