<span style="font-size: 11pt"><span style="color: #003300">A little time consuming but: 1. Get the old paint out by soaking the knob in lacquer thinner & then brushing vigorously with an old toothbrush. Scrub the knurled edge too; that gets all the dirt & finger grease out. 2. Any of the prior suggestions for white paint will probably work. I prefer spray gloss white enamel. I spray a little in a disposable container, dab on the letters & arrow with a small stiff artists brush. I put several coats on so the letters are completely filled. let it dry for several days then start sanding off the excess with wet/dry sandpaper. Start with 600 grit, using lots of "wet" (water) Go slowly; you just want to get the paint off. When you're ALMOST there, switch to 2000 grit for the final excess removal. Using the wet/dry not only gets the excess paint off, it cleans any "oxidation" from the knob surface. 3. Now spray the surface with clear lacquer. That bakelite knob (or whatever it is) loves to "orange peel" anything sprayed on it. I stand it up on the floor on a brad inserted on a piece of wood, hold the spray can 12"-16" away and just give it a LIGHT coat. (1 second!) Do that about 3 times & then you can give it a heavy coat without it orange peeling. 4. Now its a little too shiny, so in a few days rub the surface with any commercial buffing compound. I use Maguires Deep System paint cleaner. Now, if your other knobs look shoddy by comparison, use that method on ALL of them ! If you do, one note of caution: Some of the older knobs have a rubber buffer inserted in them. Be sure to dig that out before using lacquer thinner. </span> </span>
