Tony
jlaird
Haynes, page 51 para 51.5
tony barnhill
Great Pumpkin - R.I.P
I don't use Haines...I use the factory workshop manual.
But I just pulled an old Haines off the shelf & read what you said...factory manual doesn't mention anything about that!
jlaird
jlaird
And another problem solved by your friends on line. LOL
tony barnhill
GeeBee1 said:
did I miss sumthin
No...when I installed my flywheel, I didn't see the little "1/4" mark on its edge so I just fitted it with the #1 piston at TDC in the position as when the machine shop balanced everything...Jack told me over the phone that I needed to find that "1/4" mark & reinstall the flywheel with it at the top...neither of us realized the flywheel could be installed in different positions...as I studied my flywheel closely, I found part of the "1/4" mark...what happened to it was that was one of the places where they had to drill the edge of the flywheel to balance it so all that's left is the "1" & half the "/".
So, the clutch assembly will come off to decide if the flywheel must be reinstalled!
tony barnhill
Reason I didn't worry about the "1/4" mark (other than that I couldn't see it) when I put everything together is because when the machine shop balanced all my reciprocating parts, they marked the ends of my crankshaft & flywheel the way they were bolted together when they balanced the engine (they didn't worry about where the "1/4" was - or they didn't know about the "1/4" since they'd balanced the flywheel right where it was)....they "0" balanced each item & then hooked up each item individually & spun tested them untl they had the entire reciprocating assebly together.
...so, the back end of both my crank and flywheel are now marked by the machine shop the way they want them to go together & those new marks become my new "1/4" (& on the backside of my flywheel the machine shop made a black mark that points straight up when the #1 piston is at TDC).
Does that make sense?
jlaird
jlaird
All is well that ends well and Tony sleeps good again tonite.
HealeyRick Sad News - Tony Bennetto Spridgets 1
Boink Corvair - Tony Dow's Other Cars 12
Basil General MG For those who remember Tony Barnhill MG 25
Mickey Richaud General MG WHOA! Just had a "Tony" Flashback! MG 8
T Tony P Triumph 5
J TR4/4A Tony's car back on the road. TR4 Triumph 3
Hap Waldrop MGB-GT Tony Barnhill MGB GT race car project. MG 17
PAUL161 Mickey, Tony's Web Site Question MG 1
rick_ingram MGC Is this Tony's MGC? MG 12
Wray MGB-GT Tony's GT MG 8
S T-Series Tony's TC MG 5
Mickey Richaud MGB-GT Tony's [Jerri's] GT MG 45
R tony barnhills website www.theautoist.com? Spridgets 10
Sherlock Suggestion re: Tony's estate auction FORUM Navigation Questions 1
Hap Waldrop Tony Barnhill's collection MG 11
v8mgbal fix it again tony Spridgets 17
R From Tony Barnhills Obituary In Todays Newspaper MG 1
Hap Waldrop Tony's Midget? Spridgets 29
AngliaGT Tony "Tribute" Decals? MG 2
T I miss Tony MG 43
JPSmit Hey Tony! look here Spridgets 7
jlaird Last one for Tony MG 12
jlaird And even more for Tony MG 10
jlaird More for Tony MG 2
jlaird For Tony MG 2
PAUL161 Hap, Doc, Tony, have you heard of this stuff? Restoration & Tools 14
martx-5 Tony's [RATCO] High Idle Triumph 16
RickB Tony - Need a trailer & a 67 Midget? Spridgets 8
58Custom Tony Barnhill-- I sent yuou an email about parts. Spridgets 11
jlaird Tony, status report Spridgets 3
Trevor Jessie Here ya go Tony Spridgets 32
jlaird Tony Spridgets 0
fabmandan Pics for Tony and John-Peter Spridgets 15
Basil Tony! Spridgets 2
Morris Hey Tony! Spridgets 3
zimmy tony-order sent Spridgets 18
JPSmit another one for Tony Spridgets 2
Hap Waldrop Tony's HS2s Spridgets 16
jlaird This spot reserved for Tony Spridgets 4
Hap Waldrop Thanks Basil, and Tony FORUM Navigation Questions 0
jlaird Always wanted to do this Tony Spridgets 1
JPSmit O Tony! Spridgets 30
C Tony why aren't you bidding on this car? MG 36
PAUL161 Tony - - Jag 120 coupe ?? MG 7
PAUL161 Tony MG 4
Steve Minor Pickup for Tony.... Other British Cars 10
G ZS water choke question for Tony Barnhill. Triumph 3
JPSmit A sad pic and one for Tony Spridgets 4
bugimike And Another Cool Utility Vehicle [Tony?] Other British Cars 21
Steve_S Oh Tony... YB on eBay MG 11
