Tonneau snap replacement - any tips?
tdskip
Hi guys - need to get at least some weather protection going on the '74 TR6. I have a decent tonneau, but is it missing the rear deck lid snaps. Any tips on repleacing them and if any vendor has better snaps than others?
Thanks!
Gliderman8
Snaps are easy to install... my only comment is to use a hole punch of the correct diameter to make the hole in the tonneau. I got mine in a fabric store and it has a wheel that rotates with a few different sizes.
It yields a cleaner hole than using a sharp object to make the hole.
Hobby Lobby carries them (snaps) for $.15 ea. I made a good installation tool out of an old pair of vise grips pliers. Used an old socket ( correct hole size), ground the edges off sharp for punching the holes. They've been working for many years now.
Marv
BobbyD
If you're real lucky you'll have a friend who has a Press-n-Snap tool. With this tool you can install all 18 snaps on a boot cover in about 10 minutes with no need to pre-punch any holes. Here's the tool and a boot cover I sewed up a few months ago. It's not a cheap tool but if you're going to do a bunch of snaps or grommets, it a real time saver and installs the snap/grommet perfectly every time.
T
tdskip
So my car has holes in the rear lid area - are those supposed to be there. They are close to where the tonneau snaps want to go, but not exact.
Andrew Mace
Well, there oughta be enough holes for snaps for the tonneau or boot cover. Any filler in that area? Perhaps someone filled around there and then, for whatever reason, randomly drilled holes they thought would be useful for snaps. It wouldn't be the first time I've seen that.
I remember once convincing a buddy with a Spitfire MkIV that he "needed" a nice tonneau cover for his car. (Ok, I just happened to have a nice tonneau but had no use for it!) He went for it...and I spent about an hour carefully probing around the top of each door to find the three tonneau snap holes that I knew had been there before he'd had the car repainted. Found them, riveted in new snaps and he was set! :wink:
T
tdskip
Hi guys - anyone have a close up of the location of the snaps on the back deck/lip handy?
Fair to assume that the TR4as and TR6s used the same snap locations?
Thanks!
DNK
Is there a dependable location, I figured none where really alike. Are you installing in the body or the top?
T
tdskip
Hi Don - I figured that there <span style="font-style: italic">might</span> be a stock/standard location. I can always locate them to match the existing snap locations on the tonneau but wanted to ask I started making holes in the car.
DNK
I would match them to the top you will use. I think that's why tops don't always come with snaps
T TR2/3/3A Tonneau cover snap install Triumph 14
G Snap locations for BJ8 tonneau Austin Healey 10
Popeye TR4/4A Tonneau or top cover? Triumph 12
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
Celtic 77 Wanted Tonneau MG Classifieds 4
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
pbraun Bugeye tonneau pattern Spridgets 1
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
Upland Tonneau cover repair Spridgets 2
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
jackq MGB New tonneau cover in box MG 1
T supporting BE tonneau cover during heavy rains Spridgets 10
A TR2/3/3A Pegs-top and tonneau Triumph 3
L Wanted WTB: Bugeye tonneau cover with roll bar cutouts Spridgets Classified 0
I For Sale TR6 tonneau cover Triumph Classifieds 5
Hangtown Healey BJ8 tonneau cover bag Austin Healey 6
T Securing the Tonneau on a 3000 MkII Austin Healey 4
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
J Wanted WTB: TR3a top and Tonneau Triumph Classifieds 2
CessnaTPA Tonneau Install Question Austin Healey 13
H Tonneau cover Austin Healey 2
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
K For Sale TR4A tonneau cover.... Triumph Classifieds 3
Keith_M bugeye tonneau fittings Spridgets 11
K TR2/3/3A Tonneau capping mounting questions.... Triumph 2
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
K TR2/3/3A Rear tonneau capping plates and bridge pieces for mounting the Hardtop? Triumph 3
vette BJ7 Tonneau Cover Austin Healey 10
RickB MGB Any deals for a new Tonneau cover? MG 8
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
G General TR What type of car is this tonneau cover for? Triumph 5
6 Tonneau bar color Spridgets 6
AUSMHLY Who makes a good tonneau cover for a 100-6 Austin Healey 6
K TR2/3/3A Restoring a tonneau cover? Triumph 3
Sarastro General Tech Tonneau cover vinyl restoration MG 5
mrv8q TR6 TR6 Tonneau Q Triumph 3
Jeepster BJ8 tonneau cover Austin Healey 8
TR4A_IRS TR4/4A Location for dash snaps for tonneau cover? Triumph 3
Jim_Gruber Tonneau Rail for a BE Spridgets 16
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
D Tonneau Cover Questions Spridgets 25
