tire air pressure
Jim1971
I installed 185/70/14 radial tires on my 1971 MGB. What is the best tire pressures to use in town and on the highway ??
What did the tire shop reccommend?? I would run 32 but, go by manufacturers recommendations!!
I was talking to a german fellow who used to work in the tire industry and he told me that in North America we tend to run our tires at too low a pressure. He said that the whole firestone/ Ford Explorer episode a couple of years ago might not have happened if we ran our tires at the maximum pressure.After talking to him I upped the pressure in my daily driver and my mgb.I run them both at about 35 lbs.If it works on the Autobahn it will work on our highways!
Warren
I was running the MG manual recomended pressures of front 21 psi and rear 24 psi. The car felt like the tires were too soft. I have changed to front 29 psi and rear 32 psi. The car rides a little rougher, but handles much better in the corners. Seems that front pressure needs to be a bit lower to get the feel right in the corners. My gas milage has improved also..
[ 04-24-2003: Message edited by: Jim1971 ]</p>
