Tip
jlaird
Did I tell you how to make your windsheld sparkle?
Bartenders Friend, available at any grocery store.
Wipe on and rub, inside and out. Takes it all off and cleans it to like new. Will not take off scratches but everything else.
bugimike
:iagree: Great stuff (and VERY cost-effective!)!! Try it for buffing up aluminum parts too! :wink:
That stuff is the best for cleaning stainless steel stains. :wink:
jlaird
jlaird
I learned something too, thanks.
JPSmit Today's top tip - Rain X Restoration & Tools 3
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
Geo Hahn General Tech Tip for DOT5 Users Triumph 9
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
Rob Glasgow A tip from You Tube Austin Healey 6
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
Gearhead_Garage Storage Tip for British Cars Austin Healey 10
S Hot tip: seal for fuel tank sender Austin Healey 9
Michael Oritt Rear axle tip needed Spridgets 6
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
glemon Tech Tip, Wonky Switches Restoration & Tools 3
H Su tip Triumph 7
JPSmit Cleaning Tip Restoration & Tools 0
Tinkerman TR2/3/3A Battery Box Liner TR3A Tip for the Day Triumph 5
jlaird Todays tip Spridgets 4
T Reminder on a top tip for stuck bolts Triumph 6
Trevor Jessie Eezi-Bleed Tech tip Spridgets 1
Basil Tip - Columns in posts FORUM Navigation Questions 0
apbos Undercoating Removal Practice Tip Restoration & Tools 5
B Spray paint tip Restoration & Tools 2
jlaird Need your tranny rebuilt - tip for the day Spridgets 1
jlaird Tip of the day - gaskets Spridgets 13
JPSmit Good Friday confession - and work tip Spridgets 8
J Tip lowered front suspension and bump stops Spridgets 0
jlaird Tip for today Spridgets 0
Jim_Gruber Heater Valve Leaking - Tip to fix Spridgets 10
jlaird Todays tip, Carbs Spridgets 5
M A tip for those new to Sprites Spridgets 8
D U-joint removal tip any TR Triumph 11
jlaird Another tip for Bugeyes Spridgets 2
JPSmit An installation tip Spridgets 2
jlaird Jacks tip for the day Spridgets 0
jlaird Progress tip Spridgets 1
tomshobby seatback foam tip Triumph 8
sparkydave Random tip of the day Spridgets 2
Stewart Windshield cowl seal hot tip MG 1
E Tip to remove the BMC on a '70 Midget Spridgets 6
RickB Need Tip to remove stubborn headlight trim rings MG 3
SilentUnicorn 1500 Tip of the Day Spridgets 3
jlaird Jacks tip of the day, Spridgets 3
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
jlaird Doors don't fit right-tip Spridgets 3
jlaird More on choke cables-tip of the day. Spridgets 6
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
1 Has anyone ever heard this tip? "Weeping" head MG 11
G AAARRRGH - anyone got a tip for these bushings? Triumph 11
jaybird The 'bird's Tech Tip #17 MG 42
jlaird Todays tip - Door hinges Spridgets 8
jlaird Jacks Tip of the day Spridgets 1
