Timing Mark Relocation
bugimike
Not sure about the kit, but it can be a fairly easy do-it-yourself project! Look for threads on this in the forum. Hap does it very neatly and has some pictures posted elsewhere!
I weld on top side timing pointers on the timing cover on the A-series engines when I build them. Jeff at Advanced Distributors makes a nice bolt on kit that's alot easier than my method if the engine is already in the car.
58Custom
Link for Advanced Distributor? Yahoo search brought no joy.
tony barnhill
Great Pumpkin - R.I.P
On one of the threads about my '63 restoration, I've a photo of Jeff's kit - had to do a little modifying because it not sdesigned for the 1098 engine....
Also, Hap posted a photo of the kit on one of the engines he's built.
J 100/4 timing mark relocation Austin Healey 2
tony barnhill Timing Mark Relocation Spridgets 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K TR2/3/3A Timing mark..... Triumph 1
R TR4/4A TR 4 Timing mark Triumph 10
A TR6 Timing mark Triumph 16
pkmh Setting Timing Mark For BJ8 Austin Healey 9
rlich8 Timing Mark Moving Around Triumph 21
C Timing Mark Spridgets 12
T Hmmm - no timing mark on the pulley. Now what? Spridgets 10
D BT7 Timing mark and pointer question Austin Healey 6
Bruce Bowker ignition timing mark Austin Healey 5
D timing mark Spridgets 12
mgb4tim Wedge TR7 Timing Mark Triumph 0
RandallRK Timing mark on crank pulley Austin Healey 19
Woodie timing mark - found Spridgets 10
Woodie timing mark Spridgets 42
1973purplemidget Timing Mark MG 3
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
