tie rod replacement
Wike
Replacing tie rod ends on tr6,....how do you get the securing nut tight? The whole shaft that the nut threads onto begins to turn. Someone please explain the simple tasks I am missing!
Darrell_Walker
If you need to steady the shaft, I use channel locks. But if you can't move the nut without turning the rod, I would make sure the threads are clean.
There should also be flats cast into the tie rod ends (ball joints), you can use a open ended wrench (or adjustable wrench) to hold it in place while you tighten down the lock nut.
Or are you taking about getting the tapered pin tightened into the steering arm? If so, a plain nut can be used to pull it tight, then replace with the lock nut. Though I often find that pressing it down into the taper can be enough.
Mickey Richaud
Platinum
:iagree:
As the nut is tightened, the shaft should be pulled down enough to where it holds. Give it a little help with large vise grip.
W
Wike
Thanks...the plain nut trick did the job. Lowered the car and the front tires seem to be tilting in wards at the bottom. The car was purchased over a year ago and has been up on blocks ever since. Is this normal or is it something to do with some other adjustment. I have replaced all front end suspension bushings, coil spring bushes, damper bushes, tie rods with your help, etc. Do Tr6 tires orient out of plumb slightly?
Darrell_Walker
Until you move the car back and forth a bit to settle the suspension, I wouldn't worry about it.
I don't have the specs handy for a TR6, but I believe it should have slight negative camber, i.e. the tops of the tires should lean in to the car a bit. There are shims on the lower mounting brackets to adjust that. But again, until you get the suspension settled down, you can't check it.
S TR4/4A Tie rod end rubber replacement Triumph 6
S TR4/4A Tie rod end rubber replacement Triumph 1
K TR2/3/3A Removal of tie rod end? Triumph 7
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 1
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
Feathers 289I inner tie rod end. TVR 0
D TR4/4A inner tie rod ball joint tension Triumph 0
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
steveg Tie Rod boots - urethane Austin Healey 22
W Inner Tie Rod Spridgets 3
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
D TR6 Tie-rod problem Triumph 4
M Tie rod end came apart easy - too easy? Spridgets 6
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
DornTRoriginal TR2/3/3A Tie Rod Adjustment Triumph 6
Sopwith_Camel Tie rod ends Spridgets 12
P Tightening Tie Rod Ends? Spridgets 4
H TR4/4A Tie Rod In Door - TR4 Triumph 5
A MGB tie rod ends in A-H? Austin Healey 1
Boink Tie-rod ends... types Spridgets 7
gbtr6 TR6 Question on TR6 trunnions and inner tie rod ends Triumph 6
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
M TR2/3/3A TR3 tie rod ends Triumph 6
G Separate pitman arm from center tie rod Triumph 4
mjobrien Dimensions for Tie Rod and Cross Bar for 100 Austin Healey 6
eschneider Spitfire source for spitfire tie rod end boots Triumph 17
Tabcon Tie rod ends and balljoints? Racing 3
19_again GT6 gt6 tie rod lever Triumph 2
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
A TR4/4A TR4A rack / inner tie rod adjustment. Triumph 11
S tie rod end boots Triumph 23
drooartz Loosening the tie rod jamb nut Spridgets 12
KVH Ball Joint and Tie Rod Grease Zerc Fittings Triumph 4
Cottontop Tie Rod Ends Austin Healey 0
ArkleyOkie Tie rod ends Spridgets 5
19_again Tie rod lever threaded? Triumph 5
floyd TR6 tr6 tie rod end stuck...... Triumph 20
J Failed State inspection-tie rod end..follow up Spridgets 4
J Failed State inspection-tie-rod end? Need help Spridgets 8
T Inner tie rod ends Triumph 5
