jhorton3
I've never been good with getting tie rods separated with a pickle fork, and this time was no exception. No matter how I approached with fork, hammer, spoon, shovel it wasn't going to budge. I searched around for a tie rod puller and they're impossible to put your hands on here locally. I could order one and wait a couple of days, or buy a set which was close to $100.
Then I came across a 2 & 3 jaw 2 ton puller for $34. There's probably cheaper ones around, but I wasn't going to spend any more gas looking for a bargain. I've already damaged my hand from hammering, and decided to use the air ratchet. Both tie rod ends came off with no problem. You can use a ratchet or a wrench, I just had the air ratchet close at hand and made the job a lot easier.
