Tie rod ends
Sopwith_Camel
ok ive just done the tie rod ends on Shaggy,
A they do screw on very easly?
then I couldnt get the wheels back on with out cutting off the exseses thread. I cursed Moss and got the hack saw. now haveing a home brew IPA in the late night sun. I think maybe i have the wrong part??
its a 73 rack ... i think?
steve
bug_sixty
have another IPA...and another until it make sense... ok,,,wow there're two different rod ends for spridgets but the difference is in the ID of the rack end. Did you do a visual of the new and old ends before install?
Sopwith_Camel
Sopwith_Camel
well they were a bit different in manufacture.
I just know my rack wasn't the same as my 72 spridget.
steve
PS all are welcome to drop by for a few home brews and a bed for the night
Gerard
There are different tie rod ends for pre and post-72 cars. Early is the Morris Minor rack, late is the Spitfire.
Sopwith_Camel
Sopwith_Camel
Yes i thought that was the change over.
What are the visual diffrnces?
I had to sell my 72 five years ago , wow it's been that long
steve
Gerard
steve
Sorry I don't have a the car or any pix to compare (only early type). I just know they specified by year and have different part numbers.
Sopwith_Camel
Sopwith_Camel
Yeah this is the problem of building a car out of spare parts bin, ten years on figuring out what is what is difficult.
aeronca65t
The older (Morris-Minor type) steering rack has a 5/8-18 UNF thread.
The new rack uses a smaller, 1/2-20 UNF thread.
The changeover to the new style rack was made around '72, so your car should have the older (bigger thread) tie-rod ends (but it sounds like it's been changed to the '73 rack?).
In these older cars, it's hard to guess what has been changed before. It's easy to put a newer rack in an older car. And be sure you don't have the wrong steering arms. They looks similar but will not work properly and have a different taper-hole.
I hate the idea of you sawing off a section of the thread. Be sure the tie rod screws in far enough so that you have enough thread engagement....otherwise, it would not be safe.
Here's a link so you understand what a "steering arm" is. It's not labeled but it's just above "4a" in the photo.
https://www.mossmotors.com/Graphics/Products/Schematics/SPM-032.gif
Sopwith_Camel
Sopwith_Camel
The part I cut is the threaded bolt above the nut because it collided With the wheel.
the main sleave screwed on to the rack easily.
I ordered a new set if they show up and are the same ill will put them with the rest of the Spairs.
If not then I'll put those on.
focused on the jag this week before the eu inspection. It's making a clunk from the front left wheel when I step off the brake.
Sopwith_Camel
Sopwith_Camel
no im on the standard steal items ..
bottleing a over hoped "bitter"
steve
G
I had to grind a bit off mine. The tip would tear stick on weights off the rim. It's a really close fit and mine are supposedly stock ends.
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
P Tightening Tie Rod Ends? Spridgets 4
A MGB tie rod ends in A-H? Austin Healey 1
Boink Tie-rod ends... types Spridgets 7
gbtr6 TR6 Question on TR6 trunnions and inner tie rod ends Triumph 6
M TR2/3/3A TR3 tie rod ends Triumph 6
Tabcon Tie rod ends and balljoints? Racing 3
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
Cottontop Tie Rod Ends Austin Healey 0
ArkleyOkie Tie rod ends Spridgets 5
T Inner tie rod ends Triumph 5
A TR5/TR250 TR-250 Source for "new" inner tie rod ends Triumph 4
G tie rod ends Spridgets 4
M Ball joint/tie rod ends Triumph 8
drooartz Tie rod ends, how to remove? Spridgets 9
vping Tie rod ends. MG 27
X Removing tie rod ends MG 5
X Tie rod ends or boots MG 1
X Tie rod ends MG 9
jaybird Tie rod ends MG 25
J Help me ID these tie rod ends MG 3
Bret Need a Pickle Fork to remove MGBs Tie Rod Ends Restoration & Tools 15
K TR2/3/3A Removal of tie rod end? Triumph 7
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 1
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
Feathers 289I inner tie rod end. TVR 0
S TR4/4A Tie rod end rubber replacement Triumph 6
S TR4/4A Tie rod end rubber replacement Triumph 1
D TR4/4A inner tie rod ball joint tension Triumph 0
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
steveg Tie Rod boots - urethane Austin Healey 22
W Inner Tie Rod Spridgets 3
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
D TR6 Tie-rod problem Triumph 4
M Tie rod end came apart easy - too easy? Spridgets 6
DornTRoriginal TR2/3/3A Tie Rod Adjustment Triumph 6
H TR4/4A Tie Rod In Door - TR4 Triumph 5
W tie rod replacement Triumph 4
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
G Separate pitman arm from center tie rod Triumph 4
