Ticking noise from car when driving
Paulus
So having just removed and refitted the transmission I hear a ticking noise when driving, not sure if it is related to what I have done or not. Anyone else had similar experiences or can throw some light on this?
/ubbthreads/images/graemlins/england.gif
Brosky
Could be your speedo cable. Is it binding or dry?
Paulus
Paulus
I've only taken it up to 30mph, end of street and back. Sounds like I'm hearing it from outside of the car, so it is probably coming from underneath.
Simon TR4a
Try pushing the car in neutral on your driveway while someone else listens to try to identify the source of the sound.
If you can hear it when the car is running it should be quite loud.
Does the ticking occur once per revolution of the wheels?
Does it go away if the car is put in neutral?
Try to narrow it down by a process of elimination.
Simon.
Geo Hahn
Diagnosis of small sounds can sometimes be aided by driving alongside a wall, first on the drivers side, then the passenger side. Nice wall behind my Home Depot that works great for this. As noted try in different gears and coasting out of gear and even engine off coasting, etc.
AltaKnight
My TR6 makes a noise like that and I finally narrowed it down to an out of round drivers side brake drum.
The noise goes away when I touch the brake pedal or pull a little on the handbrake.
I had to use the reflective wall to figure it out as mentioned above.
MadRiver
[ QUOTE ]
[/ QUOTE ]
How are you getting along with SWMBO? Could be a bomb!!! /ubbthreads/images/graemlins/jester.gif
D Ticking noise when driving Austin Healey 8
Cutrog1 Fuel Pump Ticking Austin Healey 13
warwick-steve Ticking fuel pump Austin Healey 7
vette Slow Ticking Pump Austin Healey 19
M Fuel Pump Ticking Austin Healey 7
AH67 facet fuel pump never stops ticking. Austin Healey 6
E Ticking from right side airbox Jaguar 15
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
B New fuel pump - loud ticking, now fuel spraying! Austin Healey 33
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
S TR2/3/3A Noise from clutch area? Triumph 20
P TR6 Clutch pedal click noise Triumph 2
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clutch pedal noise Triumph 2
P TR6 Clunking noise in rear continuing Triumph 39
R Clutch Throwout Bearing Noise? Austin Healey 2
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
F TR2/3/3A Strange Loud Noise Triumph 11
Michael Oritt Clutch-related noise Austin Healey 14
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
G Tappet Noise Austin Healey 8
TulsaFred Generator or water pump noise? Spridgets 20
S Disconcerting engine noise, please help if you can. Austin Healey 56
2billydavies TR2/3/3A rattling noise on TR3a Triumph 12
J MGB Project car done; front end clunk noise while braking MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
RAC68 Loud Trans Scrapping Noise Austin Healey 9
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
K TR2/3/3A Gearbox noise.... Triumph 8
P TR6 Rear suspension noise Triumph 3
bugedd Rear end noise [insert joke] Spridgets 11
Lukens TR2/3/3A Cog v-belt causing noise. Triumph 8
P TR6 Clunking noise in rear Triumph 2
busybrit MGB Slight starter motor noise MG 5
N BJ8 Noise when going from reverse to forward Austin Healey 2
J Funny noise in my mini British Motor Corp 12
P TR6 Thumping noise Triumph 15
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
Lutz Kramer Noise from the engine compartment Austin Healey 21
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
