throttle return springs
eurobiketrash
Member
anyone have any pictures or can tell me how they have any throttle return spring attached? There has to be a better way than what I am looking at!
Keoke
Naw they work great when adjusted correctly--Keoke-- :laugh:
Keoke
eurobiketrash said:
actually after looking at this birds nest; there are springs I havent seen before being used to pull the choke back!
Yes those can be a problem since to my knowledge they are not available as replacements.Consequently, they are made by stretching a pair of throttle return springs to the proper length and installing them.Stretch them too much and they will not work. WHEN STRETCHED TOO LITTLE THEY WILL ALMOST BREAK YOUR ARM PULLING THE CHOKE OUT.---Keoke- :laugh:
58Custom How many throttle return springs? Spridgets 1
Baz Throttle return springs... Spridgets 86
R TR2/3/3A Carb throttle return spring tension Triumph 2
catfood Throttle return mechanism on the BN1 Austin Healey 4
apbos H1 carbs and throttle return spring? PS BillM this pic is for you! Spridgets 5
D TR6 76 TR6 Throttle Return Triumph 8
R TR2/3/3A TR3 THROTTLE RETURN SPRING? Triumph 11
T TR2/3/3A TR3 Throttle linkage return spring Triumph 3
Stig Throttle return spring location Triumph 5
19_again fourth spring on throttle return? MG 16
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 22
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
M Throttle pedal problem Austin Healey 8
bighealeysource Strange problem with throttle staying open Austin Healey 6
A Throttle Pedal Height Austin Healey 17
Bob_Spidell Throttle Bushes Austin Healey 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rob Glasgow Overdrive Throttle Switch Austin Healey 9
Rut TR4/4A SU throttle linkage and brackets Triumph 5
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
P Bj8 rhd cable throttle conversion - help Austin Healey 6
