MGB Thought to ponder: Analysis Paralysis
Boggsy64
When I got my car I basically jumped in and drove 2200 miles across country. Now that I know all the things that were wrong, and what can go wrong, I hope I have the guts (or ignorance) to just get in and go off into the wild wonder again!
With a few tools aboard and some spares you can go as far as you want to!
WillR
im looking at the same size trip in the next little bit. just got my 30 day temp plates today. I feel the same way. soooo many things, when do you trust your trouble shooting skills enough? im going through it real slow and hoping i get all the stuck on the side of the road things out of the way. they have priority over trivial things like heaters:nightmare:
Have ya got "connectivity" across your route?? If so, we're here! There ain't much to go wrong with a B that can't be addressed with a good set of tools and some MacGuyver knowledge. Wire coat-hangers, some J-B Weld, Duct-Tape and Channel-Loks. If it ain't fixable with that kit, ya need a tow.
WillR
so far Denver Colorado, and Rose Park, just out side Salt Lake City are my two rest points. My drives not set in stone yet either. Im thinking follow 80 on the side roads. I have no overdrive and dont want to redline the whole drive. i feel a bit better as i immediately found a purpose for everything you mentioned. Triple A card holder here to. As much as i want to take a more Southern rout, florida just might be pushing it. As of now i have been away from my new bride longer then we ever got to live together. im so close. A few more days of not this.
Temp plates are in my hand. hope to get tires on the ground tomorrow or the next day
drooartz
I'm in Midway, south-east of Salt Lake City. If you need anything while you're coming through town, let me know.
WillR
iv never seen a bug eye up close drew. whats your definition of "need" :smile: I appreciate it brother. we will see what shakes lose over the drive if i come over those MTs limpin youll be the first to know.
Boggsy64
Boggsy64
Will, my B does not have OD and I started out slow keeping it around 60 max. As the trip progressed found I was cruising right along at 70 to 80 easy. RPM's did not get too high with a couple thousand to spare. Hope you have great trip!
drooartz
Just PM'd you my contact info, get in touch if you make it out here and there's time for a connection.
WillR
Thanks Drew, im looking forward to it. last time i drove it i rode the highway a lot putting on a few hundred miles a week. passing needed a grade that was going to cooperate but it seemed fine. i just am uncomfortable driving that far at a constant speed. fun fact i am in need of a new cam as my number three exhaust lobe is worn to the point of the valve opening mostly due to the pressure in the cylinder. gps has my car MAXED out downhill at 82 mph. i dont want to do a new cam with out reworking a few other things. A motor by hap or at least a kit from him is on my wish list.
Boggsy64
Boggsy64
Will, that gives me some hope for the status of my engine (last thing I plan to rebuild). It did consume a lot of oil, but the car pulled fine and passing was no problem. I got it up to 90 once or twice getting by some big trucks. Maybe a ring job and lapped valves are all I need. I was (still am) concerned what the cam and crank will be like.
WillR
When i got it home the first time I leaned on the fender looking in the motor i heard a huge pop and the car dropped. bushing completely gave up the ghost. so i took the cross member off and went through the suspension front and back. Poly bushings and rebuilt the shocks. oh and i painted the front springs red to match the bushings :smile: rode great after that. while i was under there i could remove the oil pan. thats how i saw my crank. I put two and two together and knew where the putter i had was coming from. So far i am very impressed with the bulletproof design i am noticing.
As embarrassing as it is to admit i once noticed my oil at nil so i pulled over bought some and watched the gage rise then drop. i saw it pump out right on the ground. line from the pump broke. drove it twenty miles that way home. no noticeable difference in power sounded MAYBE a bit more clicky from the valves. got home parked it till i installed a new oil line. No problems sense. solid pressure. its a tank.
WillR
enough hope to take a drive later this month? :highly_amused:
Deleted member 8987
Six. Outside of Denver. Old hiway. Ups and downs. Mostly two lane.
Kurtis TR4/4A Random thought... Triumph 8
Hap Waldrop Thought I would share this video Racing 6
Steve Thought I'd Share A Few Photos.... Other British Cars 5
DanLewis And I thought the Bugeye was small... Spridgets 6
Keoke Who would have thought it !! Austin Healey 7
jlaird Thought I would share 50 years with a BE Spridgets 14
M Humor me with a thought problem related to part availability... Spridgets 8
G TR2/3/3A You thought you had seen it all ! Triumph 5
DanLewis 'Just thought the rest of you Bugeye fans would want to see this! Spridgets 1
RickB Thought I saw a 210 - but it was just a B Spridgets 6
tinman58 Who would of thought? Triumph 3
B The thought of this makes me sick Triumph 13
sd80mac7204 Random thought Triumph 13
CZ_Dave I thought I had seen it all MG 2
mjobrien Thought you folks would find this interesting.... Austin Healey 1
Hap Waldrop Hap will be on track sooner than thought :] Racing 19
Darrell_Walker Wedge Thought exercise - a wedge as a daily driver? Triumph 86
A I thought my project was a challenge! Triumph 18
W So you thought $2100.... Spridgets 3
rovernut Thought for the day Rover / Land Rover 3
I Just a Thought on Parts Spridgets 6
6 I thought I was doing good Triumph 8
1 GT6 1970 gt6 floors first look- not as bad I thought! Triumph 16
JPSmit Not one I would have thought of Other British Cars 6
hilsideser food for thought Triumph 10
T And you thought you had a nice engine bay... Triumph 18
RickB I thought this ad was funny - Midget on Craigslist Spridgets 3
jlaird Thought you might like to see what I Spridgets 29
Steve1970 thought i seen it all... Spridgets 3
RobT TR5/TR250 So Ray Magliozzi Owned a TR250! Who wodda thought Triumph 6
T OT - and you thought your paint has issues Triumph 13
T OT - and you thought Triumphs rusted.... Triumph 1
W eBay BE ...I thought this was only for the bonnet Spridgets 5
DrEntropy Colloquial but thought it interesting: Racing 4
T My wife thought she was in Lamaze classes......... Triumph 11
JPSmit Bugeye thought Spridgets 12
Atrus Random Daydeam thought - LPG Sprite Spridgets 10
R Thought I had one Austin Healey 6
jlaird Thought I would share this. Spridgets 4
jlaird Had a thought Spridgets 6
jlaird Thought you all might like these. Spridgets 24
E TR6 TR6 Diffy - Dumb ? But Thought I'd Ask Anyway Triumph 4
T And I thought my Midget was small! Other Cars 2
jlaird Thought you all might Spridgets 1
jlaird Thought I would share Spridgets 6
jlaird Thought you might like these Spridgets 3
jlaird Thought you might Spridgets 10
pbraun I thought it was a 100-6, but it's a BT7 3000 Mk I Austin Healey 5
J thought you guys might like this TVR 2
YankeeTR And YOU thought you had a parts stash.... Triumph 4
