Thermostat
Anthony_S
Hello, Is there a specific way to tell if the thermostat on my TR3A is going out or is bad. Im pretty sure it is still functioning but part of me thinks not to its full potential. Driving it this last fall it seemed to get warmer than it should and when I tapped on the thermostat housing it would seem to cool down a bit. Maybe I am imaging all this but was curious what ya'll think.
Thanks
Anthony!
DNK
Pull it out and stick it in some water on the stove with a thermometer in it.
Turn the stove on and watch.
Another way is get an IR temp reader and point it at the housing.
Tap it and see if the temp changes
These are just guesses
gubba
Just replace it..theres a couple of differant kinds..summer or winter..after that if you still heat up you got other problems.
TR3driver
Great Pumpkin - R.I.P
With my IR thermometer, you can get a 20 degree or more variation, just by slightly changing the exact point you "shoot" on the housing. The emissivity of old aluminum varies all over the place (and is nowhere near the value assumed by the thermometer).
https://www.engineeringtoolbox.com/emissivity-coefficients-d_447.html
TR4nut
If it is an original style bellows thermostat, the way you tell they've gone bad is your engine temperature pegs. They fail in the closed position when the bellows loses its seal. I was very lucky to catch that condition in time before it became a real issue for me.
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
Lin Thermostat and blanking Sleeve question again Austin Healey 7
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
wingsandwheels TR6 '74 TR6 thermostat housing bolts Triumph 5
