T-Series Thermostat Switch Question
MGBGirl
Member
Alright! Time for the radiator fan question. At about what temp should my radiator fans kick on? We have shorted across the fan's thermostat switch and the fans do indeed work. Just concerned that the thermostat is not working because the temp goes up and the fans don't kick on by themselves.
David_DuBois
Two ways to check if the switch is good or bad. 1) attach the leads of a multimeter to the terminals of the switch, set the meter to read ohms on the lowest scale, put witch in a pan of water and with a thermometer and bring the water to a boil - see what temperature the switch closes (reads 0 ohms), if it closes at all. 2) replace current switch with a replacement.
Cheers,
M
MGBGirl
Member
DNK said:
Well ours has 2 separate spade terminals. It must be an unusual one - can't seem to find one on the internet like ours. Probably replaced by the one you posted, then I would have to come up with a new connector.
M
MGBGirl
Member
Well, crap, it looks like I have the $60 one. Kinda hard to tell by those pics though. Why the huge price difference? Do you know if they are interchangable?
Grantura_MKI
Be sure to fit safety wire through the rad core over the switch. These are pron to "popping" out and cause a lot of $$$'s.
Cheers,
D.
Platinum
What he (Grantura_MKI) said... Pin th' "switch" to the rad with whatever ya have to hand... wire, zip-tie, whatever. Both those have two terminals, they're "thermocouple" switches. Just get the "cheaper" one and change the terminal ends,
PAUL161
Doc, I wonder how come the switch Moss has for cars up to 511290 is $15.95 and the switch from # 511291 up is $49.95? Crazy huh. PJ
Platinum
supply/demand I guess. The $16 one is an "Otter" switch, R&R'd plenty of 'em.
Learned that you really should replace the grommet at the same time, too. :shocked:
Tie-wraps or safety wire kinda-sorta help keep it in place. Always considered fabbin' up a "retaining device" with aluminum sheet but never bothered.
If ya use wire as a retainer ya have to be aware and NOT allow it to touch the contacts of the $50 unit, BTW.
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
Lin Thermostat and blanking Sleeve question again Austin Healey 7
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
wingsandwheels TR6 '74 TR6 thermostat housing bolts Triumph 5
