RickB
My Mk II Sprite took it's maiden voyage this evening after a weekend of work.
First (yesterday) I had to clean off all the flood muck from my concrete pad that used to be my shop (before the windstorm of ought 8).
Got that done and the lawn mowed and the little red Mk II pushed onto the pad.
Today:
I got the brakes bled and the clutch working and then bolted in the seats.
Checked all brakes, they are in new condition.
Did lots of little odds & ends, then I put 2 gallons of gas in the tank and turned the key. Oh yeah - PO had fuel pump on a dash switch.
Rewired fuel pump to ignition power and turned the key again.
No gas...
Undo connections, turn key, no gas.
All this time I had it up on jackstands, so I put all the wheels back on and lowered the front.
Got gas!! Pouring out all over the floor.
Raised the front end again, noted no clamp down where the rubber line connects to the hard line. Grab a clamp & scoot under and tighten it down.
Turn key - got gas coming out upper rubber hose.
Make all connections I loosened looking for problem, turn key and try to start. No go.
Oil pressure goes up to 20 lbs while cranking, good sign!!!
Spray in a little starter fluid & Vroom cough cough die...
Where's the choke pull on this thing.
Oh - there isn't one.
Manually set choke on both SU's and turn key...
VROOM!!!
Runs great. 50 lbs oil pressure.
Lowered car down to the ground.
Let it run until temp gauge says 140, put in clutch and selected reverse. Backs up like a dream. Put it in 1st. Right back to the work area.
Good enough for today, still have to put everything together and put away the tools.
What a great weekend! :laugh:
Now - what to do about a choke on this baby??? Ideas please?
Today:
No gas...
VROOM!!!
