The Head Gasket
DNK
On the Wedge, Composite gaskets and the head will be on for a few months with maybe only a mile or so on the odometer after the install.
Should I put something,oil(?) on them to facilitate a speedy and easy removal?
TomMull
Back when I was a kid, the "old timers" (younger by far than I am now) put grease on them. I don't think it did much, though. Should come right off with no goo at all.
Tom
DNK
DNK
Pretty sure the one I took off that had about 300 miles on it
came right off too.
Just don't want to buy a third
Darrell_Walker
When I changed mine last year, the consensus was dry.
Do the composite gaskets crush? Not sure I would reuse any head gasket, other that perhaps solid copper.
DNK
DNK
Good point Darrel.
No matter what the usage?
Darrell_Walker
DNK said:
Good point Darrel.
I would never reuse the steel TR8 head gasket, as it it meant to crush when installed.
The more typical composite-sandwich type may be OK, but given the effort to get the heads off on the TR8, I wouldn't risk having to redo it. I don't think it would try to reuse the valley pan gasket, either (and that was much more expensive than the steel head gaskets).
DNK
DNK
hmmm, Think I remember Woody saying it was OK
He didn't ship me a new one 300-400 on the old one
Darrell_Walker
Wow!
tr8todd
I would never reuse a head gasket. A local reputable engine builder had a problem with a stroker Rover V8 he had just built for a buddy of mine. The newly built engine was on the dyno and the gapless rings were causing negative crankcase pressure. He pulled the whole thing apart, bought another set of new forged pistons slightly more oversized, steel rings, and a new set of Cometic head gaskets. Point is the builder wouldn't reuse the gaskets which cost around $250 a set and he was the one standing behind the work and he was footing the bill. Engine has been in the car for a few thousand miles and so far it runs smooth and powerful with no blow by.
TomMull
Hmmm???
A new composite head gasket will certainly give the best chance of sealing properly but I've reused more than my share without incident. Hard to recommend for a mere thirty bucks though.
Tom
tr8todd
Something about the rings sealing when under pressure but not sealing on the downstroke under negative pressure. I didn't buy that explanation at first either, but the builder rebuilt the engine at his expense and all seems well. The folks from gapless rings told him to go back to steel rings.
TomMull
Interesting. Perhaps someone can enlighten us. At the risk of straying somewhat off the topic, my 92 BMW is designed to run with negative crankcase pressure. (I cracked the oil pan at a road construction site once and drove the car fifty miles. It didn't leak much at all until I shut it off and then it drained like I pulled the plug.)
Tom
tr8todd
I would assume your BMW engine has a PCV hooked up to manifold vacuum. This Rover engine had nothing hooked up to it while it was getting broken in on the dyno. At first everyone was like cool no engine blowby. Then they realized the engine was consuming oil and there was actually a small vacuum being created that you could feel when you put your hand over the oil filler. Rover V8s are known to have blowby or positive crankcase pressure. The amount of blowby is determined by who built the engine, how it was built and what parts they used. The engines with really big cams that wash lots of fuel down the cylinder walls at idle seem to fair the worst as the rings never seat well and the crosshatching on the walls gets worn away. Many of the guys with the 4.6L and up engines are using a vacuum pump to draw out excess pressure and also to create vacuum for the brake booster. That is if they are using a big overlap cam that doesn't make much vacuum. Somehow negative crankcase pressure makes more HP, but the biggest advantage is not spitting out oil pan gaskets and dipsticks every time you romp on it.
70herald
Tom
I don't know for sure but it seem to me that the neg pressure would be created by the PCV valve and there is no reason that the pressure can't be set for whatever the manufacturer thinks is desirable by balancing the amount of air sucked from the crankcase with the total blowby, leaks, outgassing.... if there is more sucked out then the pressure is going to go negative.
TomMull
DNK said:
What was my question again?
:jester:
Sorry, had to look it up. But you will admit that a head gasket change is not all that interesting? Good luck with yours. Cheers.
Tom
Csarneson Head Gasket Seal Austin Healey 6
R Cylinder head gasket BJ8 Austin Healey 32
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
KVH General Tech Head Gasket Triumph 10
RJS General TR Head Gasket Test Fit Triumph 5
D TR2/3/3A head gasket... which way up?! Triumph 8
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A Head gasket sealer question Triumph 7
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
J Blown head gasket in 3 min. a new record! Triumph 14
Lukens TR2/3/3A TR3 blown head gasket? Triumph 39
L 1275 Head Gasket Spridgets 7
M persistand head gasket leak 1959 mg 1600 MG 3
RedTR3 TR2/3/3A TR3 Head Gasket [Again] Triumph 4
RedTR3 TR2/3/3A TR3 Head Gasket Triumph 6
Boink Head gasket recommendations... Spridgets 13
Morris Blew another head gasket... Spridgets 15
Stewart I sure hope its just a head gasket MG 8
6 MGB 79 MGB Head Gasket Screwup MG 7
D Head Gasket Triumph 31
M Head gasket use sealant or not Austin Healey 7
M Head Gasket Orientation Austin Healey 2
M Head gasket replacement. Austin Healey 6
T Replacing Head Gasket help Spridgets 4
