The meter is made by Fox Valley of Cheboygan Michigan and is from the 70's or early 80's. It is an old analog meter that has been replaced by Hi-impedence digital meters. Do not use this meter on any of the newer cars with computer systems. They run these systems on very low voltages and this meter could back load higher than normal voltage and fry the comp system. In it's day this was a very good,easy to use meter and will work on any vintage British car. The leads are simple to hook up. The two leads on the meter are for the Ohms[resistance]test,voltage[DC only!!!!!] Black for ground,Red for hot[positive] and Dwell test. To hook up for dwell,Black to engine ground[anywhere],red to the primary lead [distributor side of coil Small wire that goes to the points].Select amount of cylinders for engine on meter,look up proper dwell angle of points,start engine and read angle for point setting. If it's in specs bingo!The clip type lead is for inductive tach reading.Hook black and red leads to battery,clip lead to#1 spark plug wire, select tach function anr RPM's.The funky lead is called an amp shunt and is hooked between the battery and the positive cable.It will tell you amperage in the charging system. Careful!!!! misuse can fry meter and charging system. When checking a car with a generator disconnection of battery cable while engine is running will Cause NO HARM! Disconnection of cable on a car with an alternator can fry the alternator!!!! The small red lead is for hooking up in tight places. Internally ,I believe the is a battery for OHM function. On the back of the meter remove the screws holding the four rubber feet,pop off the panel and replace the battery. I hope this info helps you. I have been in the automotive tool and equipment business for 32 years and sold hundreds of these meters in their day.
