sway bar for a 58
Do remember that the sway bar for all Spridgets up to '79 are the same (you should just have the stronger, reinforced pans to go with the bar).
They should be available used about anywhere.
BillM
Anyone dealing in used parts should have a stock bar and if you go heavier I would recommend reinforcing the front frame horns where they bolt up to. They will break!
Kurt.
