I am considering replacing the front oil seal and at the same time the chain, sprockets, motor mounts, damper, and water pump.
Is this possible on a 29D engine while it is still in the car? I am figuring the grille and radiator have to come out to do this. Can the engine be raised enough to remove the pulley bolt with an impact wrench or some other method? Or does the engine have to come out of the car to do all of this?
Any advice is welcome.
