Sunbeam V8 Tiger - any info ?
beaulieu
I am supposed to look at a Sunbeam Tiger in the next few days,
Is there a website that will show me how to tell if its a REAL Tiger or a converted Alpine
thanks Beaulieu
r67cat
Beaulieu, One of the things that can give a converted Alpine away is the firewall/tunnel area. The Alpine firewall was not cut back like the Tiger. Look for the access holes to the #8 spark plug and rear valve cover bolt. These should be located above the accelerator pedal. Though this picture does not show the entire firewall, you can see the rubber plug in the sparkplug access hole and the valve cover access plug above and to the left of it. If you know a Tiger owner that could go with you, that would help assure the authenticity. Good Luck, Rick
thegoodbeamer
A converted Alpine will in all probability have the firewall cut back like a Tiger.If it was done real good it may be impossible to tell.Look at the battery box area as in Alpine.A poor cut and weld job removing it may show up here as many think it will never be seen.The early tigers had the fuel pump here.In any case if the battery box is still there it is not a Tiger..Look at the steering rack mounting as well to see if it was converted.Tiger mods and the crossmember were spot welded.saying that it is possible an owner continuosly welded all the seams of the crossmember when doing the teck advisory of rewelding the shock towers but not likely.I did do mine when I redesigned my front end.
If possible do take a Tiger owner along as it is sound advice.If it is a very well done conversion it may still be a good buy if it is being sold as a conversion such as an Alger.
Good luck
pmenhusen
The first step is to check the chasis number. Correct Tiger numbers are as follows:
Mark I: B9470001 to B9473762;
Mark IA: B382000001 to B382002706;
Mark II: B382100001 to B382100633.
Of course it's possible that a converter could have taken the tag off a totalled Tiger and transplanted it onto a conversion, so the inspections described by the earlier posts would be your second step. I believe that there is also a Tiger registry that you could consult.
Good luck, and please let us know the results!
beaulieu
beaulieu
thanks where is the ID tag ?
and how was it originally put one ? screws or rivets
beaulieu
Tullamore
Also look for the JAL/SAL tag. Although this is screwed onto the chassis next to the Chassis Number if it starts with SAL you know its an Alpine. If it has a JAL number, contact the tiger registry and verify the JAL number goes with that Chassis Number. Don't be too alarmed if it is not there though.
https://www.rootes1.com
This website has tons of good information about the Tiger and also contains the Tiger registry.
thegoodbeamer
Yes that sight is a great one for Tiger information.I also believe it is possible to ID a tiger from the axle housing numbers.I seem to remember that part.
Tullamore
The rear axle and the steering rack are unique to the tiger. You would have to have a parts Tiger to make a beleivable clone. The only way to tell them apart would be to look for body modifications.
beaulieu
beaulieu
Hi guys
well I went and looked at it today,
very solid , all there , hardtop , no idea if there is a softop frame, wrong steering wheel
4 point rollbar
weird aluminum center/steel outer rims
all the trim and bumpers are on it ,
Motor has been worked with Edelbrock manifold etc, but its sat 12 years so its stuck.
front hood has a scoop molded in it to clear the aircleaner,
black paint not sure if original paint but is original color.
anyway looks pretty good, no price yet but will let you know,
Thanks for your help so far
Beaulieu
beaulieu
beaulieu
yep its a real one , with a box full of old receipts etc
One more question ,
if I need to change the rims are they the same as any modern car ?
Beaulieu
Tullamore
They have an unusual bolt pattern shared with the Mustang II. There will not be a whole lot of different wheel styles. Minilites are the norm aftermarket wheel.
Bruce Bowker
[ QUOTE ]
yep its a real one , with a box full of old receipts etc Beaulieu
[/ QUOTE ]
A great find then!!!!
Bruce
D 1965 Sunbeam Tiger featured on my YouTube channel Sunbeam (Rootes) 0
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
D For Sale 1965 Sunbeam Tiger Other British Classifieds 2
T Wanted Early Tiger or Sunbeam hardtop Other British Classifieds 0
Steve Sunbeam Tiger... Which one? Sunbeam (Rootes) 12
S Sunbeam Tiger Prices Sunbeam (Rootes) 2
PAUL161 Sunbeam Tiger Engine Sunbeam (Rootes) 12
beaulieu cost of new windshield for for Sunbeam Tiger ? Sunbeam (Rootes) 1
petervisor 1925 Sunbeam Tiger LSR Sunbeam (Rootes) 0
S Sunbeam tiger bushing sleeves Sunbeam (Rootes) 0
Sherlock Sunbeam Tiger Harrington coupe on E-Bay Sunbeam (Rootes) 21
S For Sale Sunbeam Alpine Factory Workshop Manual - All Models 1959 - 1968 Other British Classifieds 0
P Wanted Sunbeam Alpine SV5 Other British Classifieds 1
A For Sale Sunbeam Owners Handbook for Sale Other British Classifieds 0
Mickey Richaud For Sale Sunbeam Alpine Other British Classifieds 2
T Sunbeam/Hillman engine question Sunbeam (Rootes) 6
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
F Sunbeam/Hillman Key Blank Sunbeam (Rootes) 4
F 67 Sunbeam Minx Sunbeam (Rootes) 9
aeronca65t 1934 Sunbeam...I think British Motorbikes 3
glemon Sunbeam Alpine GT Spotted 6
dougie Sunning Sunbeam Spotted 1
P Thanks Basil!! Spridgets before Sunbeam! Spridgets 1
EricG 2 back to back Sunbeam events Sunbeam (Rootes) 6
EricG Sunbeam race article in Hemmings Sports+Exotic car Sunbeam (Rootes) 0
aeronca65t Sunbeam Tools Sunbeam (Rootes) 1
RickB Sunbeam Alpine on Seattle area CL Spridgets 1
jfslenes Sunbeam 1927 Land Speed Record Falls Sunbeam (Rootes) 5
aeronca65t Sunbeam at AACA Museum Sunbeam (Rootes) 4
aeronca65t SUnbeam Minx build Sunbeam (Rootes) 1
EricG Sunbeam Gathering- Oct. 2nd, Columbia,SC Sunbeam (Rootes) 0
zedvictor1 Sunbeam Harrington LeMans Spotted 14
Bob Claffie Old Sunbeam Sunbeam (Rootes) 0
P Sunbeam before Spridget??? Spridgets 7
glemon Sunbeam Alpine Compression Ratio Sunbeam (Rootes) 1
aeronca65t Great Sunbeam Video Sunbeam (Rootes) 1
EricG Sunbeam Invasion April 29-May 2, Hendersonville NC Sunbeam (Rootes) 5
dougie SOVREN Maryshill Hill Climb - Staring Sunbeam Sunbeam (Rootes) 0
aeronca65t Sunbeam pics-PVGP Sunbeam (Rootes) 0
EricG Sunbeam SOS-Columbia, South Carolina Sept 12th Sunbeam (Rootes) 3
T Just listed my Sunbeam for sale Sunbeam (Rootes) 0
T OT - lot of potential Sunbeam [cheap] Triumph 7
RickB NMC but what a nice Sunbeam Alpine... Spridgets 4
Sherlock A Sunbeam, but yet other British cars... Other British Cars 14
jackq 68 Sunbeam Sunbeam (Rootes) 1
Tullamore Sunbeam S9??? British Motorbikes 3
jackq Sunbeam going to crusher Sunbeam (Rootes) 7
aeronca65t Sunbeam Racer Sunbeam (Rootes) 0
S Vintage Sunbeam Race photos Sunbeam (Rootes) 0
Tullamore 1913 Sunbeam Sunbeam (Rootes) 3
