SU HS2 Piston assy movement-- question
58Custom
The piston assy on the forward SU HS2 moves further than the one in the rear carb. Always has, even before I rebuilt the engine and before I went through the carbs and installed new jets. It's a little higher at idle as well. I was just out there setting idle speed and mixture and it sounds OK but there seems to be nothing I can do about the pistons operating differently.
Any suggestions?
jlaird
Piston lift is caused by air. Pure and simple air passing through the carb. One of yours may have a bad throttle shaft or gasket on the manifold side. Easy to check. While running at idle spray a bit of carb cleaner at those places, if idle increases you found the prob.
Could also be caused by the carbs not balanced, a whole other desertation but something to think about. They should be the same. In fact they must if they are adjusted correctly.
Balance first then adjust seat.
spritenut
Look closely at the linkages, one may be opening up the throttle before the other one is, they are easy to adjust bu loosening the nuts on the links and setting them so both come in contact at the same time.
dklawson
As stated above the pistons should be close to the same height in operation. Before you go through the tuning steps, make sure the shoulder on each needle is flush with the bottom of the piston. Likewise, make sure each jet is flush with the bridge before you lower them by the 2-full turns of the adjusting nut. Before making any adjustments to the throttle linkage, remember that you must also loosen and back-off the fast idle screw and choke linkage. If the choke is not completely out of the equation you will not be able to balance the air flow and set the mixture adjustment properly.
Dave Russell
Yoda - R.I.P
It is important that the piston return springs are balanced/matched. Same tension at the same weight & length. Springs can be easily tested.
Other causes of unbalance could be different clearances between pistons & suction chambers. As in the two assemblies interchanged. There is a test to measure piston drop timing to check for matched clearances.
jlaird
You need a copy of "Tuning S.U. Carburetters.
One of our folks has it on his web site for download. Chris you listening?
58Custom
58Custom
Luke_Healey said:
Here's the little helpful video that gave me the idea of how to best determine how to match suction chambers on my HS2 carbs:
https://youtube.com/watch?v=IfU47Oqq9wA
There's a good bit of SU information contained in many of his videos. All are well worth the watch.
Hazzah! That's good stuff. Very helpful, thanks!
jlaird
May I suggest that all of us need to watch all the John Twist videos from University Motors on Utube.
This guy has got his act together and is doing a real service for LBC owners.
bugimike
:iagree: I have saved his videos in my Youtube account! They make a nice referrence file! Where is University Motors located?
jlaird
Up in Minnisota some place I beleive.
jlaird
Is a two parter utube on his shop.
58Custom
58Custom
The vids were very helpful.
I did the piston drop test and it turned out that switching the pistons made for a more equal drop. I worked on getting the opening points for the throttle as close as possible. After that, they piston opening positions at various engine speeds were very close. Better than before.
The pistons in my carbs had vacuum holes different than in the vid. You guys are probably familiar with them, but I just want to put this into the forum record. The vacuum holes on mine are recessed into a relief that extends to the sides so that a simple piece of tape will not plug them. So I grabbed an old set of foam hearing protector ear plugs. The yellow cylindrical types. I quarterd them lenghtwise, compressed them and put them in the holes. They expanded in the holes and plugged them nicely. Poifect! They are now a part of my carb parts & tools box.
jlaird
So, how does it run now?
58Custom
58Custom
I took a quick run to In&Out for a nutritious snack and it seemed to run nice and smooth. I'll need a longer run with some hills to know for sure, and then I'll check the plugs. It seems very sensitive to mixture, like it runs better when it's set a little lean by the idle test and I have it set per the book.
Luke_Healey
My journey to HS2 Nirvana is still not complete after a year with this car. The reason being that I had the same Sprite with the same carbs sitting next to it last year that whooped up on it performance-wise, so I KNOW what the carbs are capable of if they work right.
As per plugging the holes, you need two pieces of tape to plug each piston. Do just like John did in the video in order to plug the recesses on the side and top.
Also, my dashpots are slightly out of round it seems. Depending on the orientation of the pistons, they fall at different rates, so I lined them both up how they would sit when assembled on the carburetor and did the test that way to determine the match quality.
jlaird
They are sensitive to mixture, like a quarter of a flat from close to the happy spot. Actually you can hear the happy spot, it sings.
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
Rut HS2 questions Spridgets 9
R SU HS2 rebuilds Spridgets 3
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
TomMull Post-War Other SU HS2 caburetor question Triumph 9
sim HS2 Rebuild ? Spridgets 8
AN5Sprite What Needle In Your HS2? Spridgets 3
D K&N RU-4410 on SU HS2's Spridgets 37
J Getting HS2 carb jet out Spridgets 11
T HS2 needles Spridgets 1
histerical Looking for some HS2 parts Spridgets 5
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
RichBall HS2 and HS4 measurment Spridgets 7
Gundy HS2 customs Spridgets 8
BugeyeNJ58 Carb leaking HS2 at bottom of float chamber Spridgets 21
TexasSprite Rebushing HS2 Carb throttle shafts Spridgets 7
RickB Air cleaners for HS2 carbs? Spridgets 33
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
John Moore HS2 Stub Stacks Spridgets 0
T HS2 for 1275, right? Spridgets 7
jvandyke HS2 float level Spridgets 10
pakiwi HS2 - Carb Issue Spridgets 3
mccalebr Eye candy - Hap's HS2 carbs Spridgets 20
Hap Waldrop HS2 velocity stacks Spridgets 37
TexasSprite HS2 Carbs Spridgets 8
Luke_Healey HS2 question Spridgets 20
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
Luke_Healey SU HS2 needle variation question Spridgets 11
ChrisS HS2's flooding in turns Racing 5
ChrisS HS2's flooding in turns Spridgets 14
S HS2 SU dual carb throttle/choke linkage Spridgets 10
middleagecrazy HS2 floats Spridgets 9
drooartz HS2 on a 948 Spridgets 3
Atrus HS2 jet needles Spridgets 4
HAN8L1965 Float Removal-SU HS2 Spridgets 5
Atrus [2] HS2 vs [1] HS4 Spridgets 10
M Need to replace fast idle screws for '74 midg. HS2 Spridgets 1
Woodie HS2's and apologies Spridgets 16
Woodie hs2's slight hesitation under load Spridgets 40
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
SilentUnicorn hs2 problem Spridgets 7
A T-Series Switch HS2's for HS4's ??? MG 3
C How to check for leaks at throttle shafts? [dual HS2's] Triumph 14
C HS2's...big ole' flat spot! Maybe I need to just pay someone. Triumph 27
D HS2's on a 1500...good, bad or ugly????? MG 17
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
