Nunyas
When I say float bowl location, I'm not referring to the angle of the bowl relative to the carb. Rather, I'm referring to the location of the bowl fore or aft of the carb relative to the car. I was reading through my carb manual and it made reference to the bowl placement for certian installations. In particular, it mentioned placement of the float bowl forward of the carb body to prevent "starvation" (over leaning) on inclines or under hard acceleration, and to prevent over richening on declines or under hard deceleration.
I've notice that the "typical" twin SU setup positions the bowls both ways. The front carb has the bowl up front and the rear carb has the bowl behind. I suppose this evens out the changes in richness thanks to the balance pipe/tube.
Any of you have any experience with this stuff? I'm planning to switch to a single HS-6, and noticed that the carb in my posession will end up with the bowl aft of the carb body once installed on the car. I've thought about relocating the float bowl to the other side of the carb body, but the throttle and choke linkage looks like it might be in the way, and there doesn't seem to be any provisions to move the linkage to the opposite side. I do drive some relatively steep roads on the weekends, and am somewhat concerned on whether or not this might become a potential problem to contend with.
I appreciate any and all SU knowlege you folks can contribute to this topic.
