SU Carbs have strange vacuum fitting
Geo Hahn
I would think that arrangement would have some strange effects on piston rise -- can't imagine that was ever an original fitting on an SU.
trrdster2000
This could get interesting!! What in the world could that purpose accomplish?
Wayne
DNK
TR3driver
Great Pumpkin - R.I.P
My guess is that someone was trying to get some visibility into what the piston was doing while driving down the road. Not particularly effective I would think, but the vacuum inside the chamber should vary a bit with position, due to the action of the spring.
Roger
Bronze
Maybe someone's idea of a setup / tuning device? If both carbs have the same fitting, maybe you drop a couple of bits of straight wire of equal length into these and see how the pistons rise?
Keith_M
The fitting looks like it's made to accept a small diameter hose tube. I wonder if someone was trying to control the amount by which the pistons rose, either by adding vacuum or adding a controlled leak. I suppose you could dynamically control the mixture that way.
B
Bruce100
I got thinking about this, and old physics/science memories came back. Someone geeky enough to do this probably was geeky enough to make a manometer and added these fittings to use it to sync the carbs.
Andrew Mace
The fitting looks like it's made to accept a small diameter hose tube. I wonder if someone was trying to control the amount by which the pistons rose....
...or, now that I think about it, hooked up a vacuum gauge either temporarily for tuning or permanently for viewing somewhere on or under the dash?
TR3driver
That was my point. Thing is, it wouldn't show manifold vacuum at all. As long as the engine is running, the vacuum in the chamber is just enough to support the weight of the piston plus whatever force the spring supplies. Obviously the piston remains the same, and the spring is pretty light. I doubt you'd get even 1 psi difference between idle and full throttle.
Keith_M
The vacuum is created by the venturi effect from the air passing through the carburetor. As far as I understand it, it has nothing to do with manifold vacuum.
Here's another thought: I wonder if the DPO hooked these two connectors together with a tube in a (I think) misguided attempt to auto-balance the two carbs. It certainly would make the pistons rise to the same height, but that height is supposed to be determined by how fast air is rushing through the carb. I'm not sure how effective it would be.
poolboy
You got it wrong, Keith.
Putting it simply, if it weren't for a depression ("vacuum") in the manifold there wouldn't be any air movement over the jet. The same depression draws the air valve upward.
Andrew Mace
Hey, I never said it was a good idea. :glee:
Keith_M
Agreed. The point I meant to make is that the two values are not necessarily correlated. For example, under hard acceleration there is actually very little vacuum in the manifold, but there is high flow and high vacuum in the top of carb. Conversely, at idle, the vacuum in the manifold is actually fairly high (because the butterfly valve is restricting flow), but the flow is low and vacuum in the carb is low.
I think this is right, but as has been proven before in this forum, I can occasionally be wrong (but don't tell my wife). :smile:
TR3driver
Nope, not the same depression. The chamber over the piston is open to the venturi, so it "sees" roughly the same depression as the venturi, which is more or less constant. (That's the constant depression in "constant depression carburetor".) The manifold vacuum is on the other side of the throttle plate.
If you put manifold vacuum on top of the piston, it would simply slam to the top as soon as the engine started. Normal idle is around 18" Hg, roughly 9 psi below ambient. The piston in an H6 is about 3" in diameter, so has an area of about 7 sq in. 9 psi times 7 sq in would be 63 pounds of force pushing the piston up.
Think of it like washing your hands. The pressure inside the water pipes is what pushes the water out, sure, but it is much higher than the pressure at your hands.
poolboy
Perhaps I should have said the "source" of the vacuum was from the manifold, for the sake of simplicity if not technically precise either.
When I said "same" I did not intend it to be interpreted as equivalent or to expand into the whole 4 stoke cycle or Bernoulli principal.
I understand your desire expand the concept, though, so I've still left plenty of room to do so, Randall or anyone else.
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
69MGC 65 to 67 carbs wanted MG Classifieds 4
K 66 Austin 1100 Carbs British Motor Corp 1
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
M Cooper's Air Filter on H1 Carbs Spridgets 5
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
sundown TR6 carbs Triumph 2
doc50 Su carbs for a Metropolitan? Other British Cars 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D BJ8 Carbs Overflowing Austin Healey 20
T TR2/3/3A Will 5W/20 oil work ok in carbs Triumph 4
R TR2/3/3A Rebuilding H4 carbs Triumph 8
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
Jim_Gruber Screws for HS-2 carbs Spridgets 5
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
HighAltitudeTR3 TR2/3/3A SU H6 Carbs all out of whack!! Triumph 14
J Backfire through carbs Austin Healey 3
wangdango Colortune for HD8 Carbs? Austin Healey 55
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
