Stuck on the Road
KVH
I thought my battery died, or that my starter was shot (the latter thought almost always being wrong), but it turned out that I just had loose battery cables. I've never had that issue with any other car. Are TRs more sensitive to connection issues?
TR3driver
Great Pumpkin - R.I.P
No more so than any other 50 year old car!
KVH
KVH
Right. At least one rule seems to apply with these great old cars--when something goes wrong it's usually something simple.
poolboy
That's because everything on 50 year old cars is simple..relatively speaking.
It's us that complicate things
Geo Hahn
I actually leave the ground post loose enough that I can pull it off in an emergency -- never had a problem with that but I do keep the post and clamp shiny clean.
When I saw the subject line I was ready to put my pants back on and hit the road.
KVH
KVH
I was stuck for awhile. Not a good feeling.
Thanks Geo. I actually feel lucky knowing I've got friends like you who can fix anything anywhere anytime. And who'd come running.
I'd do the same for you. Except you'd prove the exception to the rule. No way it would be something simple. Take care-and I'm cleaning those posts right now.
Mickey Richaud
Gee, Geo - thanks for that visual! :devilgrin:
Don Elliott
I was driving home from a TRA event many years ago through south-western New Jersey. It was a nice qiuet sunny morning and motoring was smooth on this rural road - almost all the way to the top of a long hill. The engine lost its electrical power. I coasted slower and slower till I reached the crest of the hill and pulled over into some grassy area so I could be seen by cars approaching from both directions.
The wire clip on the black/white wire on the low voltage side of the coil had failed and the wire was sticking up. It took about 5 minutes to strip back some insulation, wrap in under the hex head nut that holds it on my 1958 TR3A and then I was back on the road again.
Another very simple fix.
71MKIV
Which is why at the very least I carry my leatherman tool for just such situations
KVH
KVH
Re: Stuck on the Road--Further to the Point
Well, now I'm not sure it was just those cables. I cleaned them and put them back on, and the car started right up. But last evening when I turned the key, there was a slight pause and hesitation, like it was dead. Then it suddenly started again.
Connections at the ammeter and solenoid are good.
I can think of three things: a) cables still not clean, b)dead spot on starter; c) faulty ignition switch.
Have I hit the major culprits?
Geo Hahn
Could of course be a poor connection at the ignition switch or starter. If it is at the starter the connection may get noticeably hot. You might give the igntion switch connections a wiggle to see if they are tight.
When you get the failure to launch -- do you hear the solenoid click?
TR3driver
I have also seen bad solenoids & batteries act that way. Also don't forget the ground strap from the engine to the frame.
I don't recall offhand if a TR4A is wired the same way, but on a TR3, the connection between the battery ground cable and the body is a common trouble point, especially on restored cars. You have to have a good, clean, metal-to-metal connection and many people are loathe to cut through their expensive paint job. One solution is to put a big 'star' type lockwasher between the cable end and firewall, so the teeth of the star can cut through the paint and make connection.
3798j
Bronze
This was exactly my problem (for more months than I'd like to admit). A star washer took care of the "dead key turn" for good.
Mark_Gibson TR6 TR-6 Back on the Road , and A Stuck Hood! Triumph 3
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
Boggsy64 MGB Truly stuck now MG 10
