T-Series Stuck exhaust valve on 54 MGTF
classiccarguy
Hi all, I have a 54 MGTF that has a stuck open exhaust valve on cylinder 3. The car has been sitting for several years. From looking at the top of the head and valves it looks like possibly someone had just done a valve job before it sat up. Any ideas how to free up the valve without removing the head? Yesterday I sprayed PB Blaster. Thanks!
David_DuBois
It is possible that by removing the rocker assembly, you can spray the PB Blaster around the valve stem and the valve guide (a better penetrate would be Kroil or a 50/50 mixture of acetone/automatic transmission fluid) and then gently tapping on the top of the valve stem with a piece of wood between the top of the stem and the hammer. If this frees the valve stem, then work more penetrate between the valve stem and the guide and work the valve up and down to get things completely loosened and working freely. When putting the rocker assembly back in place be sure that you torque the bolts properly. The smaller (8mm) bolt should not be torqued more than 19 ftlb. You can find a complete set of torque specs in the chart, Torque Values for TD and TF Fasteners in the Other Tech Articles section of my Homepage at: https://homepages.donobi.net/sufuelpumps/ E-mail me at SUfuelpumps@donobi.net for more information.
Cheers,
C
classiccarguy
I took your advice and kept spraying PB Blaster (could not find Kroil locally). I pried up gently with a screwdriver and the valve popped up. However I still have 0 compression in that cylinder. Being an exhaust valve, I figure it is burnt. Do now I need a new head gasket. Is there any where yo buy one, but Moss? About $70. seems pricey for that. As always, any help is really appreciated. Thanks as always, George
PAUL161
George, First try something, if the valve is now loose, with the rocker arm off, take a brass hammer and tap the valve stem hard enough to drive it down at least a quarter of an inch, but not enough to pop the keepers. Keep doing this for a couple minutes making the valve slap in the seat. It is a possibility that a gob of carbon is causing a bypass. If this brings up the compression a bit, the valve might not be bad. It will be rare if it seals completely. Bad news is, yes the head should come off! Is your engine a XPAG or an XPEG?
Contact Little British Car Co for a head gasket, as they are a Moss distributor and give a 10% discount on the same part that Moss charges full price for. Jeff is a nice guy and very prompt on replying. PJ
Moss-$69.95
LBC-$59.46
Email LBCarCo@LBCarCo.com
Web site https://www.LBCarCo.com
Does the cylinder head have bronze guides, the reason I ask, is machine shops commonly botch this, a bronze guide requires about .003" clearance which is more than than cast iron guide, due to the expansion rate of bronze. Failure to put the correct clearance on the guide to valve stem on a bronze guide can cause seizing of the exhaust valves.
PAUL161
Remember, some heads have round holes and some oblong. I think, but not sure, the late heads have round holes. PJ
Brinkerhoff
Man I love the optimism ! If ever the term " mission creep" ( cadged from University Motors) fit a particular car it was the T series MG ! I'm not seeing how you'll just get by with only buying a new head gasket to fix this engine but I'm on your side . I'd wait until I had the head off and got a good look inside . I always find more money to spend once there. You'll be into hoses and gaskets and other sticky , pricey things soon. Make one parts order so the UPS costs don't eat you up.
MGTF1250Dave
Aloha,
If the other suggestions do not prove successful, perhaps Hal has identified the problem as a sticky valve guide. I have had a recurring problem on my XPAG engine with a burnt exhaust valve on #4 cylinder (twice since head was rebuilt in 2004). Inspection by another machine shop found that the new bronze valve guide was not reamed to sufficient clearance causing the valve to stick. Hopefully a little reaming and a new valve will solve that problem.
If you are unsure of the originality or history of your XPAG engine you may not have the head that left the factory with the block. Here is some info from Neil Cairns book, Engines for MG's, Their Story After 1935:
The 'casting number' is not the 'part number' normally. It is the number of the wooden 'pattern' used to make the casting. The same 'pattern' may well be used for different applications decided upon by the way it is machined. This way a cylinder block may start as identical items but end up as a 1250cc MG TB engine or a Marine version of the Brockhouse 'Morris' boat engine; or a MG YB engine or the Wolseley 4/44 version. They will be differentiated by their 'part numbers' stamped into the machined metal or on a riveted tag. That on the cylinder block appears just behind the dynamo, the one on the head is on the top face.
Casting Numbers.
Model/Item...............................................................................Casting Number
路 Early Morris/Wolseley Ten 1140cc 'X' cylinder block, oval,...................... 22500
路 Later post war 1140cc cylinder block, oval water holes,.......................... 24144
路 Very early 1250cc block with no timing chain tensioner,..........................24001
路 Early M.G. 1250cc 'X' block, octagon cast in, oval water holes,.................24142 & 24146
路 Later post war 1250cc M.G. block, octagon cast in, oval holes,.................24445
路 4/44, later TD, & TF block, no octagon, round water holes,......................168421
路 Early 1140cc cylinder-head, no centre oil drain, oval water holes,.............22812
路 Later post war 1140cc head, same as early 'T' type, oval holes................22952
路 Later TD, & Y oval hole cylinder head, short reach plug,..........................22952
路 4/44, TD & TF head, round water holes, long reach plugs,.......................168422
路 Late 4/44 head, round water holes,.....................................................168425
My engine had a later TD head that uses short reach plugs. This head has oval holes not round holes like original TF head with round holes and long reach plugs. This can lead to confusion as to which Head gasket to use. Again from Neil Cairns book:
THE ROUND HOLE HEAD GASKET CAN ONLY BE USED IF BOTH HEAD AND BLOCK HAVE ROUND HOLES.
Any other combination, use the oval holed gasket.
C
classiccarguy
WOW! I am really impressed by the kmowledge, down to small details, you have on this forum. I have worked on MGs over the years, but never a T series. This is a totally different car, it seems. And yes I am an optimist. I thank each of you for the advice and I will heed it and when I find out the situation I will let all of you know. Again many heartfelt thanks. George
PAUL161
Had that happen on my 55 TF with a newly rebuilt head. Cured the problem by shooting PB Blaster down the stems and by putting Marvel Mystery oil in the fuel as a top lube. It works! PJ
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
Boggsy64 MGB Truly stuck now MG 10
T TR2/3/3A Stator tube, wires stuck Triumph 15
KVH The Shifter Again--and I'm Stuck Triumph 10
A TR2/3/3A First Time TR3A Owner with stuck engine Triumph 10
KVH My Shifter is Stuck Triumph 10
KVH Stuck on the Road Triumph 14
bighealeysource nut stuck on wire wheel hub on BN2 Austin Healey 18
M Stuck front brakes? Spridgets 8
P Stuck with wire wheels Triumph 19
T TR6 TR6 J-type OD stuck engaged Triumph 9
M Stuck Nuts! Spridgets 8
bighealeysource BN2 trans gear lever getting stuck Austin Healey 8
bighealeysource Help - hood stuck on my 100-4 Austin Healey 17
