stromberg float source or x referance
Jerry
The TR4 that we are working on has floats in the strombergs which look like raisins. IE: they are wrinkled and cracked. So we have been looking for new ones. Moss has them, but they also list plastic ones in the E-type area. Are they the same carburators? Can we use the E type floats, they are half the price. I found a souce that says they are 175 Strombergs. But why are the floats listed as a different number?
Jerry
TR4nut
Joe Curto has the good ones, very nicely made for the TR4. I highly recommend them.
titanic
The floats on the pre-emission ZS carbs as used on the TR4 are different from the later "emission control" types used on TR250-6, E type, and others.
Berry
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
R TR4/4A Tr4a, Stromberg float setting Triumph 6
R Zenith Stromberg CD 175 float replacements? Triumph 3
I zenith stromberg float brass plug removal help Triumph 14
GT6_Mark Stromberg CD150SEV Float Chamber Vent Valve Triumph 12
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 2
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
B Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg carbs Triumph 8
R TR4/4A Tr4a, Stromberg rebuild Triumph 6
glemon Rebuilding stromberg Carbs Throttle Shaft Bushings Triumph 6
TR4 Stromberg Choke Issue Triumph 3
S Question on rebuilding Stromberg carb Triumph 24
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
R TR4/4A Tr4A , Stromberg carburetor Triumph 20
R Stromberg adjustment screw tight 175CD Triumph 10
