Stromberg Dash Pot Oil
JoeMad
Hello! I was wondering if you folks had any suggestions on what type of oil I should use in my 1965 TR4 Stomberberg carbs. In my old TR6's, I used to use ATF, but someone told me that using ATF is a not good. I bought my TR4 from the original owner, and he said he used 3 in 1 oil, which I found hard to believe. Do any of you folks have any suggestions on what type of oil should be used in Stromberg dash pots?
V
vagt6
You're going to get a wide range of opinions on this one. My Triumph mechanic, who's very experienced with these cars, swears by good old 3-in-1 machine oil. I've used it in two GT6s and it works great.
Everyone else, please chime in!!
Steven
use the same oil you use in your engine, and DON'T overfill it. I believe the dashpot plug should indicate hesitation when pushed down.....about 1/4" above the carb neck.
waltesefalcon
I use gun oil. Friend of mine uses engine oil. From what I know pretty much any quality oil will work.
TR4
I've been using 20 weight oil in my 65 TR4 with good results out of my Strombergs. You have me thinking we should both try different weights and note the results. The heavier the oil, the slower the pistons rise in the carbs and hence a richer mixture. That would equate to a quicker response for sport driving. A thinner oil is recommended for street use I'm told. Someone please verify this if you could.
sammyb
The reason people give all types of answers is that there are all types of correct answers.
The type of fluid you use in Strombergs and SUs depends on many different criteria. The first is the condition of the carbs themselves. If the carbs are strong, and recently rebuilt, 20wt is generally what the manuals specify. If your carbs are good, but old, ATF is a typical good substitute.
If you drive your car in the cold, going for a thinner oil is fine. If you drive in the heat of summer, a thicker oil is fine.
3-in-1 is very, very, very thin oil, and many times will result in fluttering.
You should also consider if you are using stock needles and ignition tuning. How you have your car set-up will indicate if you want those pistons to come up faster or slower.
I've used ATF, 20wt, Marvel Mystery Oil, 40wt, and even 50wt in different carbs. I use ATF now, and it works great for my car in the current situation.
Steven
i don't think any kind of transmission fluid should be used in the carbs when the manual specifies regular oil. You could just get the dashpot oil for Strombergs that is marketed by Victoria British, and call it a done deal.
sammyb
The only problem with the actual dashpot-spec oil is that if your carbs are worn, or needles are different, the dashpot oil tends to be way too thin, and you can get fluttering.
Bugeye58
I've had carbs that I had to use a different weight oil in the front and rear to get them to operate the same!
Steve, I think 90 wt. would be a little overkill. You would probably have to hook the throttle cable directly to the piston to get it to move at all. /ubbthreads/images/graemlins/grin.gif
Jeff
Geo Hahn
[ QUOTE ]
My MGB manual recomends 20w50 for the z-s carb
[/ QUOTE ]
That is what I use just because that is what I put in the engine and am driving in mostly hot and never cold conditions.
The 90 wt gear oil would be about the same weight as 20w50 (engine and gear oils measured differently) but would have a sulfur component that I would be wary of.
D Stromberg Dash Pot Screws Jaguar 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg carbs Triumph 8
R TR4/4A Tr4a, Stromberg rebuild Triumph 6
