Stromberg Carb 'O' ring
CuriousGeorge
The black caps that screw into the top of the carbs have 'O' rings on them. Should this 'O' ring fit flush into the top of the carb body, or is it ok to be a little too big to do that?
tom628
Re: Stromberg Carb 'O' ring
On my ZS carbs the (white) caps have fiber gaskets (not "O" rings). They sit flush against the top surface of the damper tower.
Tom
TR3driver
Great Pumpkin - R.I.P
I agree, flat fiber gaskets, not O-rings.
Available from TRF as P/N ZEP5439
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 2
M General MG stromberg carb MG 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
H Stromberg Carb Sync and adjust Triumph 6
JPSmit Stromberg Carb Question Triumph 15
A XKE Series II Stromberg Carb Upgrade Jaguar 4
S Question on rebuilding Stromberg carb Triumph 24
T Stromberg 150 CD carb question Triumph 4
dklawson Improvising Stromberg Carb Tools Triumph 14
J TR4/4A TR4 Stromberg Carb Question ? Triumph 12
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
P GT6 GT6 stromberg carb question Triumph 6
SCguy TR4/4A TR4 Stromberg Carb. adjustment Triumph 12
M Stromberg Carb Problem Triumph 5
K Stromberg carb question Triumph 4
S stromberg carb adjusting Triumph 2
Got_All_4 STROMBERG NEEDLES FOR 3 CARB SET UP Triumph 2
johnrip Zeinith-Stromberg Carb K+N Air Filters Triumph 8
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
B Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
