Strange Turn Signal Problem...
Fox
On my way to work this morning in noticed I had no turn signals? So I flicked the hazard lights on, (they worked) then the turn signals worked, this has happend before a few times aswell?
Very Very strange!
Any Ideas Anyone?
Bad switch? Bad earth?
Bad switch. it needs a good cleaning with a eraser. the switch can be dissassembled (carefully) cleaned at put back in service. or you can buy a new one.
mark
jcatnite
I think it is actually in the hazzard switch. My midget does the same thing if it has sat for a while. If I don't have turn signals I can fiddle with the hazzard switch a couple of times and viola...turn signals again. I plan to remove the switch and see if I can clean the contacts up a bit. That is where I would recommend you start.
JC
F
Fox
Its strange, theres no turn signals at all until i flick the hazard switch... Then they work fine!
jcatnite
I'm pretty sure power for the turn signal is actually routed through the hazard switch. If the hazzard switch is off, it supplies power to the turn signal switch. When you turn the hazzards on, it cuts power from the turn signal and drives the blinkers on its own. I'm sure that is over simplified but I would definitely start with the hazzard switch. Probably just corroded up a bit.
JC
sultanoswing
1980MGBLE
I have the same problem - simply turn on your blinker and slowly move the hazard rocker switch without actually turning on the flashers until your turn signal works. That usually works with my car. If not, just clean the contacts in the switch.
Nunyas
hmmm... interesting... what's more interesting is that I seem to have turn signals and no hazards with my '76 'B. heh.
sultanoswing
NP. It's a great site and it's helped me no end to tidy up the wiring on my B, wire relayed headlamps, upgrade the alternator etc. So far, with nothing I haven't been able to sort out...and if I can do it, anyone can!
SoS
LLAngus
I used the site to trace down my signal problem and ended up buying a signal stat for $2.80. That cured my problem. Thanks Sultan for the hint.
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
racingenglishcars This is a strange one! Spridgets 9
