Stock engine color or what?
2wrench
Okay. I'm at the crossroads of picking the engine
color. I suppose the original engine color for a '74
TR6 is likely satin black...yes?....No?
Anyway flat black, satin black, either one doesn't flip
my trigger, except to say it's original.
I thought I'd just keep it simple and paint the sucker
with POR 15 Black. Only thing is that it is a glossy
black finish. I think I'd like it cause it is shiny and
would look clean when washed (I think).
Whatdoyathink? If I go high shine on the engine block,
do you think I'll be sorry? I think it looks cool to have
the head a dfferent color than the block....real cool like
Paul Rego's red or something.
I was thinking shiny black block and a silver head.
(My car is Carmine Red and that would look bad with an
engine red, in my view.)
Or, will I be sorry because later I want original and then
the cost to repaint is awful?
Help me, please, Forum.
:winner1:
Hey D!
I went with matt black because a shiny surface
is more difficult to trace the origin of oil leaks.
The matt surface shows up oil and water very well.
Paul's colored red head is awesome!!
My vote- matt black
d
Tinster said:
Hey D!
My vote- matt black
d
Thanks, Tinster. So is matt black, like, satin finish?
Is that the stock color? Somebody will probably tell
us.
I always liked machinery gray. Nice epoxy-like finish that cleans easily and shows leaks and cracks.
There is a light and dark shade of gray; both look equally nice. I feel dark is a little classier looking while light more racey.
Excellent choice PeterK!!
But I wish I'd thunk of it when I stripped my block (in place)
and painted it matt black.
Wow- grey would look awesome indeed.
You sure you ain't right brained?
d
My new engine will be red to match the head. Even the newly rebuilt damper is red with white timing marks.
For added bling, I have the timing cover and valve cover being chrome plated. I'm also adding the Wizard Cooling Aluminum radiator.
Sorry Dale. You know that I love your color selections and I did the frame parts in grey, but to me, a hot new engine has to be RED!!!
JMHO - and only that!
2W,
I just realized that you said your body paint is red and I take that to mean the your engine compartment is the same. I agree with you about the RED/RED theme. I thought that you had painted your engine compartment black some time ago.
My mistake --- Oops!!!
With red fender wells black and silver or all silver would look nice. OK, Dale, I'm almost at the grey.
First I was thinking about black with silver head.
Now I'm kinda thinking about going silver engine with
a black head.
I guess nobody has said anything about what the
actual stock color is. Sounds boring, I suppose.
Kinda beginning to lean to silver with black head,
maybe. Whadoyathink?
on a red car the silver w/ black would be hot....assuming its clean. i thought if i do it would be green with the black car, but dark gray, hummm.
Here is the original paint on a Spit the Dolomite engine in my other Spit is the same.
I would stay away from POR15 on the engine. Unless you get a hi-temp, I don't think it will take the heat.
Also, if you decide to repaint at some point, you will have a real task at hand. Scuffing POR 15 is hard enough on a smooth surface let alone a rough casted iron surface.
I went for aluminum, with some BRG.
Now, those two engines look really good!!
How about a silver block with red head?
