stock 70 air filters
Woodie
I beleive there are hoses that run from the back (top) of both air filter housings (for twin su's) thru a "t" into the valve cover. in the pic attached the hose is disconnected and the air filter housing is not there, is this assumption correct??
The Y-pipe actually went to carb bodies then to the charcoal canister. If you have the earlier model carbs, then they will not have the ports. If they do have the ports, but you don't have a charcoal canister, then run it to the timing chain cover. If you don't have the ports, then you will need to look at incorporating an EGR valve set up I believe.
Wait, I just reread your post.
OK, the line on the tappet cover should go to the above mentioned charcoal filter canister, but if you don't have it, the you could run it to the air filter housings, or plug it and used a vented oil filter cap.
Woodie
Woodie
HMMm well if you can see it in the picture the valve cover vent is capped. and The right hose is attached to the rear carb, and the front (left) hose is plugged. By the way what is the green "can" with a port on top just to the right of the fan blades??
This setup was how the previous owner had run the car for several years.
That can is the timing cover/oil seperator. It must have a vacuum source or you will most likely have positive (at best neutral) crank case pressure and extra oil leaks.
If the front carb does not have a port for the other side of the Y then you have mismatched carbs. It will be tricky to balance them if one has a port and the other doesn't.
Woodie
Woodie
Ok , I will check for a port on the front carb. If not I will have to work hard at balancing the carbs for this summer and replace the front carb next yr. Or can I just close off the port on the rear carb?
Where does the vacuum come from for the timing cover/oil seperator?
Lots of questions sorry
The Y-pipe hose should go to the front cover.
If you block off the rear carb you won't have a vacuum source unless you rig up an EGR valve on the intake manifold.
Can you connect just one side of the Y and get a balance? I dunno. But I would think it would be possible but not optimal.
Woodie
Woodie
Ok I modified the picture. IS this correct?
Thanks for the Help
Yes, and the other side of the Y goes on the front carb if there is a port there.
Woodie
Woodie
EXCELLENT, Thanks, This baby will get started this weekend for sure...
Originally, I think the '70 had a charcoal canister and air pump. If I were you, I'd try to find and refit the charcoal system, but the air pump is a waste of time.
Woodie
Woodie
I'll keep my eye on ebay for one, but is this a performance issue or an environmental issue. This car will not need clean air testing
I guess it is an environmental issue, but it will make the car smell better (esp if you park in a garage). But it certainly will not reduce the performance.
Woodie
Woodie
I will look, but not urgently. I thin I should look for a matching carb with the port on it first.
I just sold my set of SU's and two junk pairs back in January. Don't be in a rush, ask around before paying alot for a set off of ebay. I'll look to see if I have another cannister when I get back out to my "stash" ;-)
And actually, a member of my local club had a set of SU's left over from his old midget. I'll ask about them the next time I see him.
jlaird
Just for arguments sake, Bugeyes only have one hose from cover to one carb air cleaner and a pipe on the side that dumps on the road.
Woodie
Woodie
Thanks,, is it just a new cannister or a whole n/used carb that I need
Neither of those have the tubes. You are looking at the choke cable "holder".
I Stock bugeye air filters Spridgets 9
E Painting stock air filters Austin Healey 7
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
G TR6 TR6 air filter element replacements for stock housing Triumph 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T Stock Air Filter Orientation Spridgets 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
D Stock oil filter vs spin on filter Austin Healey 17
R Planing my built. Stock vs transplant Spridgets 58
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T stock bugeye front springs Spridgets 4
T Milling a head on a Stock 1275 for compression? Spridgets 13
T TR2/3/3A Is stock TR3A windshield tinted or clear? Triumph 9
CraigCootsona MGA 6x15" wheels on a stock MGA? MG 18
K TR4/4A TR4A Stock AM Transistor Radio Fuse Size? Triumph 14
