Still Looking for the correct fly wheel ring bolts
Tinkerman
Evening All:
I have been looking for what to me. would be the correct flywheel ring gear bolts. The bolts that I took off were grade 8, 5/16" X 24 by 1", partial thread. All I seem to be able to get are grade 5 in that size. Am I wrong in thinking that I'm cruisin for a bruisin by using the grade 5? Worrys me. What have any of you used? The original ones don't look too good. This is for a TR-3A.
Thanks, Tinkerman
G
Re: Still Looking for the correct fly wheel ring b
I don't think that grade 8 is enough. I would look for 12's. I am pretty sure that TRF has them.
Oh, and by the way, does anyone want or need a brand new ring gear for a TR6. Am I wrong in thinking that it should fit the 3 and 4 as well. Brand new, still has the cosmoline. Cheap.
G
Wait, why do you have bolts holding your ring gear on? I thought this was pressed on. I was thinking about the clutch plate. 12's here.
TR3driver
Great Pumpkin - R.I.P
I don't believe they are particularly hard; I doubt the originals were better than Grade 5. This is low-tech stuff, they didn't use hardened (expensive) components unless they had to.
However, I note that the ring gear bolts did not have a 'standard' hardware part number, so there was something special about them. Possibly the shank diameter or length were specified as larger than usual.
TRF has them listed, P/N 112653.
Never seen or heard of anyone having trouble with those bolts (tho TS39781LO didn't have them until maybe 10 years ago when I converted to the later flywheel). So I'd worry more about them backing out under vibration, than not being strong enough for the job.
Both earlier and later TRs just used a press fit instead of bolts anyway (although the press fit does sometimes fail on a TR6).
martx-5
Grade 8 bolts should be fine. I've found them at my local ACE hardware store, but in the 1" length, they are threaded all the way. You may have to go to a longer size that is unthreaded at the hex, and cut them down. You can also get them at McMaster. Just search on 'cap screw' and it will walk you through the selection process. McMaster doesn't show a partially threaded screw until the 1-1/2" length.
Edit: To expand on Randalls thought about the vibration. I just looked at my flywheel, and noticed they have locking plates that fold up on the flats of the bolts, so apparently the Triumph engineers thought that they should be positively locked in place.
TR3driver
I'm pretty sure the TR6 ring gear is different than TR3-early 3A; and quite certain it's different than TR4. For one thing, the TR6 ring gear is pressed on, while the TR4 is held with bolts.
martx-5
So is the TR4A, as I have one of those because I'm doing Herman's Toyota gearbox conversion, and it uses the TR4A-TR6 clutch pressure plate.
DNK
Check ARP. Might be(read definitely) spendy
Bugeye58
I looked at the ARP site before I posted the Aircraft Spruce link, and didn't see anything listed. I checked APT, too.
Jeff
DNK
call them they have a lot of stuff that is not listed.
DougF
You would be best to replace them.
I was never a big believer in the thread stretching of a capscrew until I sat through a demonstration with the
Skidmore/Wilhelm equipment for the proper testing of used capscrews.
Lesser quality fasteners can lose 20+% torque after the initial tightening. The number drops significantly after each subsequent torqueing.
The tests I watched were with Grade 8 fasteners.
The parts I've always been concerned about are the threads in the casting.
70herald
I bought ARP head studs / nuts for the Herald and was surprised that they were CHEAPER than the Indian / Chinese stuff sold by the Triumph suppliers. I ordered from Summit Racing, and the part came straight from the ARP factory. Very good service and price. I think that you should call ARP and find out if they have the correct parts. If they have a part # call up Summit for a price.
Just one thing about the flywheel bolts, If they are the same as the 4 cyl versions, the diameter at the top is larger than the thread size.
Tinkerman
Tinkerman
Bill: the way I understand it the earlier 2's and 3's hsd pressed on rings while the later 3's had bolt on. The one in my engine was a bolt on.
Jeff: thanks for the Aircraft Spruce link, I found the bolts I need and am putting together an order of other grade 8 goodies that I need.
Appreciate all of your help!!!!!!
Tinkerman
TR3driver
Right. The change happened in mid-1959, and affected the flywheel, ring gear, starter and transmission/bellhousing. It's important to get the starter that matches the flywheel, as the gear diameters were changed (later starters had a bigger gear, so the ring gear was reduced accordingly). But it gets very confusing, since the flywheel & starter can be interchanged as a pair between early and late engines; as can the transmissions. It's not at all unusual to find swaps or even mismatched components.
I did it myself when I converted TS39781LO (which originally had the early flywheel/starter/gearbox) to a TR4A style clutch & TR6 gearbox (& suitable lightweight starter).
The bolt-on ring gear (and matching starter/bellhousing) continued to the end of TR4A production.
jlaird I am still looking Spridgets 17
R Still Looking Austin Healey 5
B Still looking for various parts. Spridgets 8
Nelson Warranty still good Spridgets 3
B Does anyone still make or sell a quality condenser? Austin Healey 14
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
sparkydave Odd discovery, but still ran OK Spridgets 1
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
K TR2/3/3A What is the name of this bracket and is it still avaiable? Triumph 4
RAC68 Directionals, Still a Pain Austin Healey 25
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
steveg Steering rebuild followup - still issues Austin Healey 29
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
K For Sale TR3 grille....not perfect but still useable. Triumph Classifieds 2
C elusive amswersHi Mine is a 66 BJ8. I have 2 questions that up till now I still canno Austin Healey 2
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
GTP1960 General Tech Still in business? Triumph 3
KVH General Tech Still on the Body Work Triumph 6
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
KVH General TR Still Losing Oil Triumph 5
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
BJ8Healeys The scammers are still at it Austin Healey 3
I Quantum Mechanics Ltd still in business? Spridgets 7
CZ_Dave MGB I'm still around MG 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
M Backfiring through carbs still Austin Healey 17
wangdango This BN2 still around? Austin Healey 6
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
R And Still Cooler in Florida Austin Healey 3
mgedit TR2/3/3A Still Overheating ... Triumph 22
Kleykamp TR2/3/3A Still fighting turn signal issues. Triumph 1
bigbadbluetr6 TR6 TR-6 still not running right Triumph 31
G MGB STILL working on clutch slave MG 37
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
rjc157 I Donald were still alive Austin Healey 15
RAC68 Still being Surprised Austin Healey 7
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
P T-Series Does my Mark II TD still exist? MG 3
mrv8q They're still out there..... Austin Healey 26
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
KVH TR4/4A TR4A--still won't start Triumph 16
G MGB Still working on front suspesion MG 9
Jim_Gruber Spring is getting closer - What Spridget Winter projects do you still need to finish Spridgets 13
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
dougie Still Time for Christmas Austin Healey 2
