Steering Wheel Resto Paint Ideas ?
Andrew1
Hi Gang and Happy New Year!
I have successfully removed the trafficator head and steering wheel on my Bj8 with the intention of restoring some cracks at the wheel's spokes. I have followed the amazing trafficator repair instructions that were posted and revised in July 2005.
Rather than restoring the trafficator's faded rough bakelite face using the india ink shoe polish method described, I was considering priming and painting it at the same time as painting the repaired steering wheel.
Here's the challenge, I am not a paint expert. Would it be wise to use a basecoat clearcoat technology to paint the steering wheel and trafficator bakelite. I have not been able to find a definative recommendation on painting a steering wheel with a durable black coating? Enamels, epoxy paints.... I'm lost.
Any recommendations on specific brands and types of paint primer to use on plastic?
- Andrew -
Randy Harris
Paint is really not your best option for restoring your steering wheel. Assuming your wheel is original, it is made of plastic. Paint will not hold up to the task and it will always look painted - which of course they were not.
After thoroughly cleaning it, you should polish the plastic part of the wheel using automotive-grade abrasives, starting at 400 and working up to 2,000 grit. In my guitar building, I use a product called Micro Mesh. It is phenomenal stuff that can take you from dull flat all the way up to mirror shine, Regular everyday high quality wet/dry paper will work too. Then hit it on a buffing wheel with polishing rouge. You can make a buffing wheel using a hand drill and an inexpensive buffing attachment found nearly everywhere. The bakelite can be refurbished using shoe polish and buffing wheel.If you Google around, I think you'll find some instructions for returning bakelite to like-new condition. But remember, there's no shame in your wheel showing a bit of age. The bakelite looks just fine as it ages, it's just not jet black. After all, your car is 40 years old.
Hope this helps.
Randy '66 BJ8
John Loftus
Andrew,
I did not paint mine when I repaired the cracks because I was concerned with scratching/chipping the paint since the steering wheel gets so much handling. If you do go that route you might want to check the offerings at the Por-15 website as they have some durable chip resistant paints. On mine, I used West system epoxy (found through boat supply stores) with fillers and black epoxy paste for color to fill cracks and sand smooth. The final coat was unfilled epoxy with the black paste color and it smoothed out to look like an original finish.
Also, for painting plastics there is an adhesion promoter called Bulldog, avail. through auto paint stores that works really well but it's designed for flexible plastics like modern bumpers, etc.
Cheers,
John
Skip & Lynne
I used Micro Mesh on some Walnut interior parts on my airplane, I ended up with 20,000 grit (yes the number is right 20,000 grit)it felt like soft leather. The window trim looks like glass that is about 2 ft deep. It is really good stuff. Skip
Bruce Bowker
20,000????? And I thought 2000 was as about as fine as anyone would want. 20,000 must really polish nicely.
Bruce
Bruce Bowker
[ QUOTE ]
Cheers,
John
[/ QUOTE ]
Was that brushed on?
Bruce
John Loftus
[ QUOTE ]
Bruce
[/ QUOTE ]
Yes, it takes 20 minutes or so to set up depending on temperature so it has time to flow out.
Keoke
Hi Andrew, contrary to popular demand I painted all my steering wheels using PLasticote Universal Black rattle Can paint. Then water sanded them and buffed them out. The only downside of this technique IMOP is do not wear rings and the wheel will be just fine and look like new.---Fwiw---Keoke
John Loftus
Putting on a quality leather cover is a good way to protect the wheel, make it more comfortable and adds thickness which I find more comfortable.
Cheers,
John
GregW
Platinum
Of course, you could always break the plastic off and put some nice wood on… /ubbthreads/images/graemlins/thumbsup.gif
Keoke
Yes John, I found some plain cloth black covers at the $0.99 store that I use to fatten and cover my wheels. When on long trips that wheel can get very hot. Similarly, at shows the cover keeps the wheels cool, prolonging their unspoiled life,---Keoke
Keoke
/ubbthreads/images/graemlins/iagree.gif Yep Greg, I got one with the plastic all broken off-What chu say your address was???---Keoke /ubbthreads/images/graemlins/laugh.gif
GregW
Platinum
Sure, send it on over. You can bid for it on ebay when I’m done. I’ll even set the reserve low for ya. /ubbthreads/images/graemlins/driving.gif
Keoke
I was just wonderin where all those wooden wheels were coming from on E-bay now I know !---Keoke- /ubbthreads/images/graemlins/grin.gif
A
Andrew1
A quick follow-up on my steering wheel project and a neat little story part hunters will appreaciate.
I have drilled, cut out and removed the cracked plastic on the original wheel and use a sandable epoxy putty made by POR15 to fill the spaces. I have primed and preped the wheel for painting and then decided to use a two-part epoxy paint also from POR 15 called hardnose paint in black. I decided to visit the dealer that sells the paint near my hometown called "The Guild" in Bradford Ontario.... here is the part find story.
The Guild is a high-end antique car restoration shop/museum. The manager appreciated my wheel restoration progress so far, but says too bad I did not come to visit earlier...could have saved you a lot of work.
Turns out they freshened-up a BJ8 with 15 K original miles for a wealthy client in Singapore. The guy took a test drive and hated the standard mega-wheel and insisted on a smaller modern wood replacement.
So, in the back the owner pulls out the most amazing gleaming black original wheel I've ever seen anywhere! For the cost of my materials to repair the old wheel, I now have two. Still have to paint.
- Andrew -
BlueRidge1
[ QUOTE ]
- Andrew -
[/ QUOTE ] Yep ,thats the best way to restore a steering wheel alright,some days you win!
T TR2/3/3A tr3 steering wheel resto Triumph 5
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Z For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
S Wedge tr7/8 quick release steering wheel Triumph 0
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
R Wanted wood steering wheel Jaguar Classifieds 0
K TR2/3/3A The Steering Wheel Nut Triumph 9
AUSMHLY Adjustable steering wheel removal Austin Healey 5
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
A TR2/3/3A How to restore a bluemels steering wheel Triumph 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
glemon General TR TR250 Steering Wheel Options Triumph 6
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
D E-Type steering wheel Jaguar 6
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
L T-Series 1952 TD Steering wheel removal MG 8
W Advice please on 1930's? steering wheel and rack Other British Cars 3
H Steering Wheel & Controls Austin Healey 5
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P BN2 new wood steering wheel install Austin Healey 5
M Original Bugeye steering wheel value Spridgets 3
GeorgeC Steering wheel nut size? Spridgets 3
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
BOBBYR Which steering wheel ?? Austin Healey 19
Drone Dog BT7 adjustable steering column / steering wheel Austin Healey 1
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
P BN2 Walnut Steering Wheel Austin Healey 10
J Horn/turn signal rotate independently of the steering wheel. FORUM Help 1
Z Wanted WTB - wooden Steering wheel Horn button holder [Missouri, USA] Triumph Classifieds 1
PAUL161 T-Series New Steering Wheel MG 7
S TR2/3/3A Steering wheel covers Triumph 9
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
