My recarpeting job has expanded into a few other minor projects including a new steering wheel and horn ring...but I'm having a heck of a time getting the steering wheel off my 74B. I took off the horn pad and removed the nut and tried to remove the wheel with a gear puller...and bent the wheel and chipped the hub. I have spent days spraying the hub with WD40 and Liquid Wrench and now have a wheel removal tool hooked up with about 3000 lbs of force on the hub...BUT IT WON'T BUDGE!!! Any suggestions??? HELP...will heat help? any magical tricks to this? Did I miss a set screw somewhere??? I have a new hub and wheel on the way and would like to get this hub off before I put in the new carpet.
Thanks!
Bruce
Thanks!
Bruce
