steering rack dimension
fredv
can someone please give me the dimension of the rack from ball end to ball end where the tie rods attach? i'm looking at using this R&P for another application.
thanks,
Fred V
dklawson
To complicate your question, the Mk1 rack was different than those that came later. Do you know the age/vintage of the rack you want to use?
F
fredv
thanks,
i'm looking for a rack 21 1/8". this is for a Morgan 3 wheeler replica kit. i'm trying to fix bump steer issues.
Fred V
Cottontop
Hey Fred,
Please pardon a Healey guy for butting in, but I recently shortened a Spridget rack and installed it in Big Healey.
One of the first things to do in trying to correct bump steer is to understand what creates bump steer.
I'm not trying to imply that you don't, but I didn't until I really researched the issue.
I'd be glad to share what I learned with you. Email me at tim@ntahc.org.
Tim
Michael Oritt Spitfire Steering rack dimension needed Triumph 1
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 0
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
B TR4/4A Steering rack clearance Triumph 21
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
W Advice please on 1930's? steering wheel and rack Other British Cars 3
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Rut TR6 Steering rack disassembly Triumph 2
T Steering Rack Lubrication Spridgets 3
K TR2/3/3A DIY TR3A Rack and Pinion Steering Conversion Triumph 0
B Now a steering rack question Spridgets 4
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
matmire New steering rack question... Spridgets 3
Feathers SP250 steering rack Other British Cars 18
BoyRacer Rack & Pinion steering for 3000 Austin Healey 12
T Lubricating the steering rack on a Bug-Eye Spridgets 12
Keith_M steering rack inner ball joint Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
W What is the purpose of the brown wire on this steering rack? Spridgets 19
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
doughairfield TR4/4A Steering rack placement Triumph 2
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
P TR6 Steering Rack TR6 Triumph 2
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
texbears3 TR4/4A Fan Ext rubbing Steering Rack Triumph 7
N Spitfire Question on solid steering rack mounts! Triumph 3
RickB 78 Midget steering rack lube? Spridgets 4
P Steering rack adjustment??? Spridgets 6
M Steering rack boot clamps Spridgets 14
D Steering rack shim??? Spridgets 7
Scotsman Pros and Cons to a Steering Rack Conversion Triumph 18
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
tinman58 TR5/TR250 TR 250 Steering rack ? Triumph 2
tinman58 TR 259 steering rack Triumph 1
PAUL161 Steering Rack Oil MG 6
G TR6 TR6 Steering Rack Mounts Triumph 17
P Steering rack lubrication Triumph 6
jhorton3 New Steering Rack Prices Spridgets 11
D Steering Rack Boots Triumph 3
TulsaFred steering rack attachment Spridgets 5
Got_All_4 Wedge TR7 Steering rack boot replacement Triumph 9
TulsaFred Steering rack oil Spridgets 4
JPSmit Vauxhall Steering Rack Question Other British Cars 1
smaceng Steering Rack Pinion Leak Spridgets 11
P TR2/3/3A rack an pinon steering for TR3B Triumph 9
