Steering box capacity
steveg
I'm following the advice here and elsewhere and removing the STP from my steering box.
The Penrite Steering Box Lube comes in 500ml bottles.
Would appreciate it if someone could tell me whether a single bottle will fill the steering box or whether it takes more.
steveg
steveg
Just got done filling my steering box with Penrite. I used Fred Silva's method of turning the wheel lock to lock and filling the box at the left lock point. It took a little over a bottle - approximately 600ml.
FWIW - Fred says there are a lot of Healeys out there with partially-full steering boxes. See: https://youtu.be/4UwsfMPWuGg
Pretty pricey at $26 each from Moss including tax and shipping. I see Amazon has comparable Snapper 7061017 NLGI #00 grease in a quart bottle for $12. 14oz cartridges of John Deere #0 Corn Head Grease are available for $4.
B TR2/3/3A Steering Box Capacity Triumph 7
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 6
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Walter74 Steering Box End Play Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box fluid again.... Triumph 2
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
B Steering box BJ8 Austin Healey 5
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
B Outer steering column connection to the steering box Austin Healey 6
simon1966 Steering box lubricant Austin Healey 17
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
M BN1 "in-site" steering box overhaul ? Austin Healey 4
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
K TR2/3/3A Steering Box Triumph 2
M BJ8 Steering box removal Austin Healey 8
T Steering Box Pinion Seal [?] Spridgets 1
S TR2/3/3A steering box sealer Triumph 9
Joe Schlosser BN1 Steering Box Fluid Austin Healey 13
S TR2/3/3A honing out the bushing in the steering box Triumph 9
S TR4/4A how ro grease steering box? Triumph 4
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
K TR2/3/3A Steering box assembly questions... Triumph 5
Lutz Kramer Steering box and idler bush Austin Healey 4
Lutz Kramer Steering box overhaul Austin Healey 17
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
