Starter is locking-up engine
sammyb
The engine wouldn't turn over on the TR3 I got a few weeks ago. It had been turning over fine after we had unlocked it -- we thought it was a little rust on the pistons, but evidently it's the starter!
The starter wouldn't engage (just the solenoid,) and I couldn't turn it over by hand.
I removed the starter, and voila, the engine turns.
Now does anyone know if the starter can be fixed easily, or should I just get a high torque one for my '60, and put the stock one in this '59? (both are post 60,000 cars.)
Andrew Mace
If it were mine, I'd take it to a local electrical shop and let them decide if it's worth rebuilding. Nothing against the hi-torque replacement starters, but a quality rebuild locally probably won't cost nearly what a new hi-torque one would, and chances are it'll last another 40 years or so.
Paul Johnson
If the starter is physically locking the engine, then have a close look at the drive and matching teeth on the flywheel. Very likely they're damaged.
S
sammyb
I looked at the teeth on the starter gear and they are worn badly.
Of course, now I'm at the position of trying to figure out the best way to remove the starter from the car -- through the top or bottom!?!?
I suppose I'll just remove the carbs, rather than try to loosen the exhaust. The exhaust flange bolts always seem to be frozen.
S
sammyb
Heck, who needs a starter anyway. I have a hand crank!!! /ubbthreads/images/graemlins/wink.gif
S
sammyb
I just looked at the topic from a couple months ago about taking out the starter. Of course, it was mentioned that the post-50,000 cars can get the starter out through the bottom. On my car, this isn't the case. The exhaust is in the way. So, as Sir Paul McCartney said way back on his second solo album: "it's coming up, like a flower, it's coming up."
mrv8q
Hey, Sam, I had a local, well regarded electrical shop look at my (functioning) starter just last month... They went through it, and it cost only $80. Wow, what a difference from pre-build! The owner said he'd have no trouble getting parts, if needed.
I also took off the carbs first, instead of the exhaust. It gave me a lot of room to look at other issues... Now you'll be set up to add Joe Alexander's heatshield, if needed!
Best, Kevin '59TRA #58370
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 2
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
Drone Dog WOSP Starter Austin Healey 8
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 8
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
DAVE WALSH Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
K For Sale Starter Hand Crank Triumph Classifieds 0
T TR2/3/3A Starter failure Triumph 4
S TR2/3/3A Starter or Solenoid Triumph 13
G MGB Starter and fuel issue MG 6
Rut Bugeye pull starter Spridgets 10
S TR2/3/3A rebuilding bomb nose starter Triumph 9
FlyingCat Spitfire Dead Starter? Triumph 18
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
S TR2/3/3A starter motor Triumph 6
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
M TR2/3/3A Starter and Flywheel Combinations Triumph 2
K TR2/3/3A Starter bushing. Triumph 7
C MGB Starter bolts MG 5
JimLaney Bench Testing starter Spridgets 8
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
Keith_M starter motor pinion gear -- 9 or 10 teeth? Spridgets 4
tinman58 General Tech TR3 Starter Triumph 11
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
A TR2/3/3A Help with clutch and starter. Recomendatiins please Triumph 7
W Starter Replacement Saga Jaguar 5
K TR2/3/3A Starter issue resolved.... Triumph 0
K TR2/3/3A More electrical....the Starter? Triumph 8
D TR2/3/3A starter choice Triumph 15
K TR2/3/3A More electrical....the Starter? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
D TR2/3/3A Another starter problem Triumph 2
S Wedge TR8 starter solenoid details? Triumph 3
