Gray_Cat
Thought I had the rebuilt carbs on my 55 BN1 balanced, etc. but an extended drive told me different. Fires right up with full choke, cold and I get ok acceleration but when I level off at cruising speed (be it 5 mph or 50 mph) the car sputters constantly (no backfire). Plug inspection shows all gaps are right and the insulator is light gray in color. Sorry, I didn't write down the plug info, they are Champions - recommendations for plugs? It also runs warmer than I think it should as it was only in the high 70's this AM in LA and the temp showed 210 after a couple of miles of surface street driving. I installed a new 160 degree thermostat (sleeved type), have added water wetter and the coolant to water ratio is 50% and made certain the radiator was topped up before driving.
Haven't checked the timing yet, will do so after reviewing replies. As always, many thanks for your help! Then I gotta trouble shoot the OD and see why that doesn't work.... /ubbthreads/images/graemlins/cheers.gif
