Spring, suspension and sway bar options
G
O.K, gotta do something about the suspension. RB car and I really don't want to drop it too much as road kill and pot holes are a problem around here. Lots of body roll that I'd like to ditch. How much bar is too much? What's just right for bumpy roads? Will it kill my suspension mounting points? ( with rough roads).
I don't want to go poly bushings as I still want some cushion in it. Best parts/prices? Good thing I started a brake upgrade.
hooey
first question ? are your king pin.s good
most problem is where the king pin and trunun pin fits to the A-arm
on a spridget (jack the car up with the jack under the A_arm and check if you can move the spindle up and dowm )
the stock bar should work fine but if the attachment ( links and bushing ect) have problem you will need to replace them
JPSmit
loose the bumpers, de-arch the rear springs and go for 1275 springs up front.
spritenut
7/8 front sway bar is too much for a street car.
3/4 is just right on my Bugeye.
Same goes for urethane bushings, all urethane is too much, some is good like the sway bar mounts and the A arm pivots.
lesingepsycho
I put the 520# 1" drop on mine and I LOVE them, but then, I'm a performance obsessed maniac. :devilgrin:
JACK
Gundy
I like my 400lbs coils and 1 1/2 inch total lowering.
Softer rears and the panhard rod. I'm using
tube shocks all around with the levers. Poly bushings
too.
I'm ditching my front anti-sway bar for a 7/8 tubular
one.
Still a usable street car. Makes for a fun day at the track too.
I do tend to push my car a bit...but it's just so much
dang fun.
There isn't much body roll on Mimi now a days.
:devilgrin:
I'd think the best "street" performance for comfort etc would be stock.
G
I've got too much body roll. Shorter springs don't ook like an option for me. My tires rub the top of the wheel opening at full lock when suspension is despressed, like turning onto a steep driveway. Y'all have to remember, I live in the country. I'm wondering if I can run a 7/8 to compensate for the softer stock springs and it'll still give me the same ride as 3/4 w/ performance springs? Found a 3/4 kit for $106 w/ free shipping. I clicked to buy and got hit w/ $25 "handling". I felt handled alright.
where did you find that kit. I haven't been handled lately....
m
ichthos
The stock sway bars are 9/16". I ran all rubber bushings and am happy with the results. I asked for advice on this on the forum earlier, and there were a number of problems mentioned with the thicker anti-sway bars. By the way, you didn't mention, but do you have the wishbones with the gusset supports? Very dangerous to use an anti sway bar without them. Just my two cents.
Kevin
hooey
my options
i hoPe that is not jig plate...
nomad
WOW!! Don't see a sway bar though. Coil over setup does'nt need it?
Kurt.
hooey
I don't have much body roll with my set up :smile: its is working good as is
so why add one
hooey
nope :lol: but it dose make me do the jig :banana:
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
DornTRoriginal TR2/3/3A Rear Suspension Front Spring Attachment Pin Problem Triumph 5
JBBgt6 GT6 TRiumph GT6 Front Suspension [Spring Pan] Triumph 2
Foghat73 MGB Spring compressor for MGB front suspension MG 45
I TR6 69 TR6 suspension spring choice? Triumph 7
A Spring / Shock suspension stiffness??? Triumph 6
77MidgetMkIV front suspension rebuild [spring refit specificall MG 9
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
P TR6 Spring checkup Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
longbridgehealey Clutch return spring Austin Healey 7
A 1974 2500M Spring Rates TVR 6
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
dougie SOVERN's Pacifc NW Vintage Racing Spring Sprints Season Opener Racing 5
