Spring question
svtmikey
When "they" talk about coil springs, as in "2 1/4" or "2 1/2", what does this refer to?
Is it inside diameter, or outside diameter, or is it something else?
Thanks
svtmikey
svtmikey
Thanks for the info!
Do you know what a 69 Triumph GT6 would have?
Got_All_4 TR5/TR250 Spring question Triumph 1
D Rear spring length question. Austin Healey 6
warwick-steve How low is too low? [spring question] Austin Healey 19
CessnaTPA Carb Spring Question Austin Healey 7
D MGB another spring question MG 1
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S TR2/3/3A small spring pan question Triumph 5
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
J Rear Spring question ?? Triumph 6
Tr3aguy Spring question Triumph 1
D Spitfire spitfire rear spring question Triumph 2
D new spring question Triumph 0
C Spring is here, alignment question, and gearbox Spridgets 7
H TR2/3/3A TR3 Rear Spring Question Triumph 7
B TR2/3/3A TR3 spring install question Triumph 2
Atrus Leaf Spring Front Bushing question Spridgets 6
healeynut Sticky Valve/guide/ spring question 100 Austin Healey 4
RandallRK Clutch return spring question- BN1 Austin Healey 2
JPSmit Rear Spring Bracket Question Spridgets 14
JPSmit Tonight's Question - shocks [and one spring] Spridgets 14
JPSmit Front Spring Question Spridgets 7
JPSmit Quick Spring Question Spridgets 10
TR_Jim Spitfire Spit & GT6 Rear Spring Question Triumph 10
M Spring height question MG 11
jlaird One spring off and a question Spridgets 1
bluemiata90 rear spring question Triumph 9
martyc Another silly Carb Question [piston spring?!?!?!] MG 3
C Another rear spring question Austin Healey 3
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
