ANyone have any suggestions on a spridget race clutch short of a Tilton? I toasted a WInner's Circle solid center disc, which had been clamped with a beefed-up (extra straps, replaced the rivets with 3/16" AN fasteners) at Summit last weekend. I think it would have been okay if I had not had to reuse the clutch disc, which was in the car when I blew an engine a month ago (car doing 100 mph, engine goes from 6800 rpm to zero in zero seconds = rather accelerated clutch wear). The WC disc was down to 6.6 mm, but having no alternative I put it back in. Made it through qualifying and the Saturday race okay, but in the Sunday main event it started slipping badly about 8 laps in. SInce I will be going to a lot of race weekends solo, and tow with a Subaru, there is no way I can add a pit cart to the collection to tow the car through the paddock. ANy suggestions appreciated. Flywheel I'm using is a Fidanza alloy, with replaceable friction surface. Engine is a fairly robust 1275 LP which has dynoed 115hp - thanks for tips!
